Fandango wrote:drive 20kph slower than the indicated speed.
CAMB01 wrote:Hey, iv fitted a 4AGZE into my AE92 FX-GT, i'm using an AE101 LSD box. My problem is that my speedo reads 20km/h faster than actual speed, i believe it is the speedo drive in the gearbox. Is there anything i can do to fix this problem?
Cam
RomanV wrote:CAMB01 wrote:Hey, iv fitted a 4AGZE into my AE92 FX-GT, i'm using an AE101 LSD box. My problem is that my speedo reads 20km/h faster than actual speed, i believe it is the speedo drive in the gearbox. Is there anything i can do to fix this problem?
Cam
What is the outside rolling diameter of your tires comared to an AE101, If your outside diameter is different, then it will read differently.
Also I doubt it would read 20kph faster across the board, it is more than likely a percentage difference.
Find out the gear ratios of your gbox and final drive, and what size tires you have.
Calculate what speed should be showing at 3000rpm in fifth gear, and find out what percentage it is out by.
This way you could also tell if it IS showing the correct reading.
What is the 4agze transaxle, is it the C56? I found a site that had the gear ratios, but didnt show final drive.What use is that?!
P.S. Are you sure it is wrong? Because I am sure the 4AGZE would have much longer ratios, so it would be normal for the revs to be a lot lower at a certain speed than what it was with the 4age gbox.
TRD Man wrote:Cam, You say you're using an AE101 gearbox but don't say if it's the box that came with the ZE engine.
The gearbox in your AE92 FXGT has a 4.312 final drive ratio. The box in the GTZ has a 3.944 ratio.
sergei wrote:hmm I'm using 6speed box, defenetly different final drive, in my AE101 (c52 original), no problem with speedo (checked by GPS)
my mate is using C56 on his AE82 (original C52) still no speedo problem, you might try to swap plastic gears (if they are different) off AE101 to your old one (press them out)
I assume AE101 GZE box has digital speedo sender
but AE92 is mechanical, so you are using your old speedo drive on "new" gearbox.... even if the drive is different, if you will use AE101 plastic gear (off sender unit) then it should work..
CAMB01 wrote:
Hey THA SHZ are the speedo drives the same for the LSD boxes? no matter what model it came out of?
CAMB01 wrote:Well the speedo drive in box has no plastic gear on it
Users browsing this forum: Google [Bot] and 25 guests
