Overheating problem
Overheating problem
Postby oldskoolmr2 » Fri Jul 22, 2005 5:57 pm
My lil useless AW10 randomly overheated last night, it still had water in radiator n there was no leaks as there was still pressure on the radiator cap. i think it could be those big fans arent going.. how could i check tht?
also can a 4age bolt into my aw10 without much hassle?
oldskoolmr2
Postby trdfxgt » Fri Jul 22, 2005 6:11 pm
to check your fans turn the car on let it get up to temp an wait and see if they come on if the temp rises over normal and they dont come on then you know you have a problem there... but could well be your head gasket as they wont always put water in the oil take it to a garage and get them to pressure test it
trdfxgt
Postby no_8wire » Fri Jul 22, 2005 6:39 pm
Replaced the thermostat at all? thats what the prob was on my car...
no_8wire
Re: Overheating problem
Postby Ae92typeX » Fri Jul 22, 2005 9:55 pm
the aw10 motor is the 3a isnt it?
if so, it should bolt up to the mounts fine. then you will have to do the loom ecu as well.
Although not as exciting a motor, imo, i'd keek the 3a in it- aw's are getting a little rarer, and the aw10 is even harder to come by. Just a 2c opinion anyway
Ae92typeX
Postby oldskoolmr2 » Sat Jul 23, 2005 2:18 pm
thanks for all the help you guys, really appreciate it.
i just wanted a bit more power out of my car.... if i do swap il keep in mind to hold on to the 3a motor :wink:
oldskoolmr2
Postby MR2boy » Sat Jul 23, 2005 2:22 pm
if you've got an aw10 stick it in a garage for a few years, if you want more power find a cheap aw11
**** Car here ***
MR2boy
