Akane wrote:Yes you'll need the exact same loom, bigger injectors in ST185/SW20.
RunningRich wrote:Akane wrote:Yes you'll need the exact same loom, bigger injectors in ST185/SW20.
That's rubbish, the injectors are closes enough (440cc/430cc).
Compression is different between the ST165 and St185. Other than that not much difference in parameters. Turbo/head differs of course.
Some rewiring of loom may be required if ST185 loom is used, but he would be removing a lot of the unecessary items anyway right?
