All_Fours wrote:300hp is pretty basic for a gen 3 3sgte, more boost, good exhaust and intake, you should be there (or beyond)
GT4_20 wrote:Asuming you're talking about @ flywheel figures, then working on the fact that you loose arpprox 25% for 4WD transmission, my ST205 was recently dynoed @ 308bhp
Mods?
2.5" exhaust inc downpipe and decatted. TRD panel filter still in OE air box and a Profec EBC running 16.2psi. Everything else is standard inc the steel shaft CT20b (for the time being at least )
GT4 20 wrote:Asuming you're talking about @ flywheel figures, then working on the fact that you loose arpprox 25% for 4WD transmission, my ST205 was recently dynoed @ 308bhp.
fivebob wrote:Anyway it's obvious from your figures that you used a 20% loss figure, or more likely a multiplied by 1.25, which according to my maths are the same![]()
GT4 20 wrote:Fully agree that @ wheels figures are far more important. Hence why I tend to quote any power I make @ wheelsGuess this 'discussion' could easily go round in circles as the only way you can get accurate @ flywheel (as you say) is on an engine dyno.
Err, where do you get 20% from?
184.3kW = 247bhp
247 x 1.25 (or + 25%) = 308.
247 x 1.2 (or +20 %) + = 296.
So looks like they aren't the same - according to your maths![]()
Anyway that's all just a BS guestimate, unless you use an engine dyno, and it has no relevance in the real world, HP at the wheels is what counts. Good for ego inflation though ,eh?
Mr Revhead wrote:Anyway that's all just a BS guestimate, unless you use an engine dyno, and it has no relevance in the real world, HP at the wheels is what counts. Good for ego inflation though ,eh?
not in my case! ran the ae101 on a chassis dyno in the weekend....
a whopping 51kw at the wheels![]()
seeing as theres nothing actually wrong with my car im gunna say its a rather low reading dyno!
