AE92 Levin TEMS question
Postby crispy'86 » Wed Aug 10, 2005 2:03 pm
It looks like the actuator for the TEMS is missing on the top of my strut as the guy i bought it off may have taken it off. Is there an easy way to disconnect the TEMS set-up like unplug the microcomputer and remove it?? Or does anyone have any TEM<S actuators they have had on their Levins. Or more realistically just remove the Tems as they are known to cause trouble?
crispy'86
Postby THA SHZ » Wed Aug 10, 2005 4:25 pm
hey dude , i wood pull them out they are generally nuthin but troubvle wen they are this old , and besides then u have an excuse to put sume konis in 8)
Not to mention if one aint wrkin the others wont wrk properly 8)
THA SHZ
Re: AE92 Levin TEMS question
Postby Ae92typeX » Wed Aug 10, 2005 7:30 pm
crispy'86 wrote:It looks like the actuator for the TEMS is missing on the top of my strut as the guy i bought it off may have taken it off. Is there an easy way to disconnect the TEMS set-up like unplug the microcomputer and remove it?? Or does anyone have any TEM<S actuators they have had on their Levins. Or more realistically just remove the Tems as they are known to cause trouble?
Im guessing its the same system with the supras with tems- some people used to set them to firm (or superfirm) and then remove the actuators. This would leave it in this position.
can be a useful trick if they are on their way out and you need them for afew more wof's.
imo, i'd just make sure they are all on the same setting and leave it at that. if youve got your heart on replacing them, then yea, upgrade, but as long as they are not leaking or anyting they should be fine. never had any issues with my supra ones.
Ae92typeX
Postby crispy'86 » Thu Aug 11, 2005 7:04 pm
I don't really know what they are like as the thing hasn't got any springs in it. Was like this when i bought it off the guy as part of the feal. I'll probably just swap everything from my ae92 trueno onto the levin all panels, suspension etc
crispy'86
Postby Ae92typeX » Thu Aug 11, 2005 7:22 pm
good idea, if its been running without springs the shocks are probably rooted anyway.
Ae92typeX
Postby crispy'86 » Thu Aug 11, 2005 7:39 pm
the other thing is at160 (st162) shocks are the same bolt up pattern as the ae92's and have the strut casing 15mm shorter than levin/trueno. Would it be a good idea to run these with some lovells springs??? Get away with it alright with the springs being captive??
crispy'86
Postby Ae92typeX » Fri Aug 12, 2005 12:01 am
dunno the answer to that sorry, but post it up if you try it, interested to know how it goes.
Ae92typeX
Postby crispy'86 » Sat Aug 13, 2005 1:40 pm
Ae92typeX wrote:dunno the answer to that sorry, but post it up if you try it, interested to know how it goes.
I'll put a post up in general discussions about it.
crispy'86
