Tom's ecu Questions?
Postby rowan » Fri Aug 12, 2005 4:39 pm
Hey got a tom's t.e.c.s. ecu with my blacktop 20 valve, just wondering if anyone has experience with this ecu, or has any details about what it can do? as i can't find much info about it.
Also offers or swaps on it could be of interest.
rowan
Postby Mr Revhead » Fri Aug 12, 2005 4:58 pm
http://www.tomsracing.co.jp/e/product/engine_tec2.htm
enjoy the japlish......
id say you have an earlier version of the above, probably similar to the SARD ecu i have. is it in a stock ecu case?
if you look inside youllprobably find a stock cicuit board with an extra platform added that holds a removable/reprogrammable chip....
it may have been caliprated to a certain engine, did it come with the car?
Postby RedMist » Fri Aug 12, 2005 5:08 pm
Sounds like it's pretty useless without the ROM burner.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Fri Aug 12, 2005 5:11 pm
unless it was set up for that car, or if like mine it actually makes a difference!
go to the next dyno day in your area, see if they will let you do a back to back run
Postby rowan » Fri Aug 12, 2005 5:20 pm
it came with the engine i purchased and i know it was run in the car with the engine before i bought them together, the ecu looks just like your normal ecu, except it is a toms version.
rowan
Postby rowan » Fri Aug 12, 2005 5:23 pm
any idea of tuning people that could dyno tune to this ecu?
rowan
Postby Mr Revhead » Fri Aug 12, 2005 5:25 pm
only if you found some one with the programme, and thats so unlikely
Postby rowan » Fri Aug 12, 2005 5:27 pm
mmm true true, what good engine parts do you have for the blacktops by the way?
rowan
Postby TRD Man » Fri Aug 12, 2005 6:21 pm
Rowan, as the agents for TOM'S we don't push the sale of these ECU's.
If it's an early one it must be returned for reprogramming. If a later version we can supply the data writer to enable the ECU to be reprogrammed but it is largely incompatible with any other that your engine tuner will have.
If you were looking seriously at replacing your ECU with a fully programmable one, for the cost and hassle involved with this item we would recommend you look at a LINK.
But as Warwick has suggested, there's no harm in trying it out and comparing it with the STD.
TRD Man
Postby rowan » Fri Aug 12, 2005 6:33 pm
how do i tell if its the earlier model one?
and if it does need to be returned to be retuned who do i send it too?
any info much apreciated.
rowan
Postby TRD Man » Fri Aug 12, 2005 6:40 pm
Send me all the numbers off it & I'll find out what they can tell us.
TRD Man
Postby rowan » Fri Aug 12, 2005 6:48 pm
will do.
rowan
Postby rowan » Sat Aug 13, 2005 12:58 pm
model numbers
on the front it says
Toms
performance engineering for toyota
t.e.c.s
toms engine control system t.e.c.s is
frameworked with enormous setting data
from racing scene
t.e.c.s realizes perfect engine control through the
exclusive setting-performance by the works-team that can
fufill the several electric parts' function as one package.
on the back it has these numbers'
ae111mt
no. 850043
99.02.17 ?date?
89600-tae11-mt
any help much appreciated
rowan
rowan
Postby rowan » Sun Aug 14, 2005 8:39 pm
bump?
rowan
Postby rowan » Mon Aug 15, 2005 3:39 pm
bump bump bump it up
rowan
Postby phatman3801 » Mon Aug 15, 2005 4:49 pm
pm trd man, he should be able to help you out
current project/ride: BZG levin
phatman3801
Postby TRD Man » Mon Aug 15, 2005 6:18 pm
Rowan,
I've got your info. Will pm you when I have news for you.
Bruce
TRD Man
