can someone please give me some infomation on oil temp gauge. what do i need ? how hard is it to install ? and will in work on my levin ae101 ? im new to this stuff. thanks alot
FLAWLES wrote:u realy dont want to be drilling oils in stuff
purple_beasty wrote:Or you just tee off the factory pressure guage/switch.
I said wrote:was going to suggest that, but you would need some pretty funky adapter pieces as many temp sensors have afew cm of the sensor sticking into the block past the thread.
still, if their easy enough to attain, that'd be the go.
