dx sedan owners
dx sedan owners
Postby LoRolla » Thu Aug 18, 2005 4:47 pm
i have a set of 17x7 17inch rims with 215/40/17 tyres that i want to fit to my 1982 dx sedan.
the rims wont fit the front witout hitting the strut but the rear ones fit ok.
whats the best way of getting around this?
any help would be mint 8)
Current Ride: '87 7afte KE70 Wagon
Previous Rides: 4age ke70, '89 vr4 220kw, mx73 cressida, '90 Hilux Surf mud truck 16psi
PC Customs
Building it your way
PH/TXT: 021 201 5665
E-mail: heilynbell@live.com
For all PC/HTPC/Laptop repairs, mods, upgrades and custom builds
LoRolla
Postby pervert » Thu Aug 18, 2005 4:49 pm
How low are you planning to go, my liftback has the same set-up as the sedans and getting 17's with 205's to turn full lock, and not get guard rub at all even with people in the back was a mission...so with 215's it going to be just that little bit worse.
I found you need to go $&#$% low with 17's to stop it looking stupid, they are just too big for the car.
As for your problem, the chances are you are using a FWD offset set of rims, so they won't fit onto the front without some bolt-on spacers, which are a couple of hundred usually, and require certification.
8)
pervert
Postby overcast » Thu Aug 18, 2005 6:22 pm
You have to get some spacers made by a certified engineer, should cost around about $200 a corner!!!! (thats what I was quoted by Elite in chch)
overcast
Postby LoRolla » Thu Aug 18, 2005 6:34 pm
they are a multi fit pattern. driven performance have 6mm spacers, would they do the trick? just gunna put bikkies on come wof time :)
PC Customs
LoRolla
Postby pervert » Thu Aug 18, 2005 7:37 pm
Nah you'll need bolt on spacers if they are a decent FWD offset, like 25mm ones at least.
You can pick them up second hand for $150 odd for a pair from time to time.
pervert
Postby overcast » Thu Aug 18, 2005 7:55 pm
sorry that was what I was meaning. You'll probably need to have bolt on flares so that the tyre (depending on the width) doesnt exceed past the "body" of the car. This helps avoid fines of around $200
overcast
Postby pervert » Thu Aug 18, 2005 8:08 pm
overcast wrote:sorry that was what I was meaning. You'll probably need to have bolt on flares so that the tyre (depending on the width) doesnt exceed past the "body" of the car. This helps avoid fines of around $200
Should be OK with 215's on factory guards provided they sit nice and close to the strut, so only get spacers just wide enough to clear the strut, then just roll the guards fully and cut the outside edge off the plastic inner guard in the front, should elminate most of the rub.
The ass end can be a bitch because of the torsion bar causing the whole set-up to shift over when you lower it, meaning the wheel sits way closer to the guard on one side...
pervert
Postby LoRolla » Thu Aug 18, 2005 11:15 pm
ok so where can i find sum spacers wide enough to fit my requirements?
how many "mm" spacers you think ill need?
PC Customs
LoRolla
Postby wde_bdy » Thu Aug 18, 2005 11:20 pm
Get an adjustable panhard rod to re-centre the diff, very common problem with a lot of cars. Watts linkage solves this, but probably not worth the work for an old KE70.
Callum
wde_bdy
Postby Rob_GTZ » Fri Aug 19, 2005 10:45 pm
LoRolla wrote:ok so where can i find sum spacers wide enough to fit my requirements?
20 or 25 will probably do the trick, but of course this depends entirely on the offset of the wheels you are trying to fit, You need to get out there & do some measuring. Anything anyone says on here is purely a guess
Rob_GTZ
Postby Jebus » Fri Aug 19, 2005 11:54 pm
Get some of those spacers that are a few mm thick, or maybe just washers and work out how many you need to fit them. Then measure up the total thickness and get bolt on spacers that thickness.
Jebus
Postby LoRolla » Sat Aug 20, 2005 12:09 pm
ok sweet, sat afternoon! gunna get some measuring going on :)
will let you all know what i get
cheeers guys 8)
PC Customs
LoRolla
Postby spencer » Mon Aug 22, 2005 3:32 pm
Shop around when getting your spacers made I had some alloy ones made for $100 for the pair. They did have some old steel ones I had to copy(and the guy was sort of a mate). I wouldnt pay more than $150
ms63 crown
spencer
