head machine - how far for good comp?
Postby Truenotch » Sun Aug 21, 2005 10:32 pm
The head came off the 86 this weekend after blowing the gasket so it's time to take the head to be machined.
So long as its going to get machined I figure it may aswell get a few extra thou skimmed off to give a bit more kick.
How much do you think should be taken off to give good comp but still give a lift in compression? It will most likely be using a .8mm trd metal head gasket.
Cheers.
Truenotch
Postby toyrota mota » Tue Aug 23, 2005 2:11 am
Not sure exactly how much was taken off mine when i blow the head gasket in my ae82, but it spent a hour and a 1/4 getting machined. And god it goes good now
toyrota mota
Postby Truenotch » Tue Aug 23, 2005 4:49 pm
Yeah at the moment the plan it to get 0.5mm (20 thou) planed off.
Then we'll see.
Truenotch
