EE90 To 4AGE or 4EFTE? goin in the 1990 XL Rolla
Postby Primo » Wed Aug 24, 2005 10:57 pm
I 've got and EE 90 at the momnt and i decide i will keep my car and do some changes on it
I come up with ideas that i could put 4age or 4agze
I was wondering how much does engine cost (range...) + box
and Im kind da lost i have searched about 4age black top and red top
I was thinking black top is better than the red top
I also searched cert for putting those engine into the car it didnt tell clear answer (one post that was talking about putting 4age into ae85)
Another one if i put 4agze engine in do i need brake system and ecu? is it same as 4age
If it needs one how much would it cost and if i need to ring up cert ppl can i possibly grab a fone number around wellington please
thank u very much for your help
When i was 16 it used to be $25 for a full tank
Now it cost $45+ for a full tank
Primo
Postby Alex B » Wed Aug 24, 2005 10:58 pm
Why not a 4E-FTE just for a change??
Postby CozmoNz » Wed Aug 24, 2005 11:11 pm
Nah, a direct bolt in.... whod think of that silly idea
Put a rotor in it bo!
Rayne For President!
CozmoNz
Postby gurutasker » Wed Aug 24, 2005 11:15 pm
I took a serious look at doing this with my EE90
Talk to EE904AGE about it... he's done it but said it was a hell of a lot of work.
Read some of this if you like:
http://forums.toyspeed.org.nz/viewtopic.php?t=29146&start=0
I did a bit of research into it and a 4E-FTE does sound like an easier option, and suprisingly not many people seem to have done it.
Bring the 'rolla beast to a meet sometime :D People there are a wealth of knowledge.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Postby Cahuna » Wed Aug 24, 2005 11:25 pm
I've just taken a red top out of my old FXGT shell and dropped it into an EE90 shell, the only tricky part was that the drivers-side engine mount was approx 15cm further back on the EE90 shell (for the 2E motor) than on the FXGT (for the 4AGE). We just ended up cutting the mount out of the FXGT and welding it into the EE90, didn't take too long.
Other than that it is just a matter of finding places to mount the brackets etc that the 4AGE requires and sorting out wiring (my current headache :? ). My advice is to get as much of the wiring loom out of the donor car as possible to make life easier on yourself. Bear in mind that the standard red top computer has 3 plugs, two from the engine loom and one from the dashboard loom, so you might need to change the dashboard loom. Or run the engine off a Link Plus or Motec and leave all your existing wire in-place :lol: . You may also need to put in a different fuel pump - I just swapped tanks between cars to make it easy.
Dunno the regs surrounding certs but you'll probably need to upgrade brakes and possibly suspension. Again since I had a complete donor car I just took everything straight across so it shouldn't be an issue for getting cert. Everything is pretty simple suspension-wise between the two cars, the only real differences I found was the EE90 one smaller suspension arm on the rear suspension (which I had to change to suit the disc-brake hubs) and the front sway bar has a different mounting point.
EDIT: just read the above posts' link, I agree with everything they said about the conversion. Unless you pick up an AE92 FXGT that has been crashed and just cannibalise it for all the parts you need it may be easier to just go with a 4E variant.
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Iv got it...
Postby Primo » Thu Aug 25, 2005 8:14 am
Thanks for ur replys
and i figure out that 4efte bolts on straigt into a car where as 4age needs no move the engine foward a bit in the drivers side rite?
I rekon black top 20v is faster than 4efte, i might be wrong i havn drivn 4efte b4 so.,.....
N if i put 4age engine + suspension + box then i can get away with cert?
it was from 1.3L 12v to 1.6L 20v???? so wouldn it be quite a lot of difference? Also putting Brake and fuel pump... can i get away with it?
hmm another thing... how much are the 4age 20v black top or 4efte and how much cert cost???
The guy in my work said one of his mate can do it for 350~450....hmmm
Thanks again for ur replys and.. i just need bit more help :) thnks
Primo
Re: Iv got it...
Postby CozmoNz » Thu Aug 25, 2005 2:24 pm
Primo wrote:Thanks for ur replys
last time i checked, it takes slightly more effort than that. Unless you know what your doing, id urge you to go for the 4e swap
Primo wrote:I rekon black top 20v is faster than 4efte, i might be wrong i havn drivn 4efte b4 so.,.....
4efte vs blacktop 20v, id say they are pretty equal, in stock comparason's. Then wind up the boost on the 4efte and see who's quicker then ;)
Primo wrote:N if i put 4age engine + suspension + box then i can get away with cert?
Nope, you have increased the displacement, changed the suspension, increased the power output by more than 20% (well, going off the specs toyota gave, not what a bt actually makes). So youll still need a cert :)
Primo wrote:it was from 1.3L 12v to 1.6L 20v???? so wouldn it be quite a lot of difference? Also putting Brake and fuel pump... can i get away with it?
to bad the legal tegal dont look at it that way, going from a 1.3 to a 1.6, in their eyes is the same as going from a 1.3 to 6.3, still swapping the engine.
Primo wrote:hmm another thing... how much are the 4age 20v black top or 4efte and how much cert cost???
Same price, around $300 if i remember >.>
Primo wrote:The guy in my work said one of his mate can do it for 350~450....hmmm
Would seem about right, bit lower than $450. but meh, ask for a price first.
Id suggest the 4efte.. you can get them hauling pretty easily (in comparason to the 20v), and they run on the sniff of an oily rag.
CozmoNz
Thanks very much for ur reply
Postby Primo » Thu Aug 25, 2005 11:27 pm
Thanks very much for ur reply up there and i guess black top 20v engine + G/Box will cost me around 800 bux but 4efte will cost me around 1500 + intercooler + Exaust pipe
I havn really sorted the cert.............. not sure yet... thos sorry
cuz my mate he goes to wel tec n he said if the suspension brake and engine was staight out from Corolla FXGT not after markets then it will be ok to not get a cert b cuz it was produced in same line...n goes in to corolla
n.. he recommands 4age cuz. windin up boost will shortn up the life + more hassle in the engine and they r slow or quite equal to 4age so.. i guess cost wise dunno am i got rite price for 4efte?
Primo
Postby Jebus » Thu Aug 25, 2005 11:34 pm
Maybe ya need to learn a bit/alot more before ya undertake a big engine conversion, understand what does what and what happens if ya do this, and I wouldnt trust everything your mate from tech says.
Jebus
Postby CozmoNz » Thu Aug 25, 2005 11:42 pm
You will need a cert, your increasing the displacement and on paper, your increasing the power too.
not to mention, its not undo a few bolts and do a few more up.. its a bit more work than that.
$1500 is expensive for a 4efte, i was pricing one up for my misses cynos, and found one for $450, engine, turbo, intercooler, gearbox, heavyduty clutch, ecu, loom, whatever other bits i wanted too (radiator etc). All bits attached
then again, he was getting annoyed that no one wanted it (origionally had it for $1200 and kept going down in price until i finally popped up, then we got the sw... so yeh).
by the sounds of it, you should do some research yourself, and not listen to your mates so much, its fine if he knows excactly what hes talking about (not saying i do, but.. yeh, ive got these chaps on here to smack me back in line if anything is incorrect).
Blacktop engines and gearboxes (especially 6 sp) are getting very very expensive, so $800 would be lucky to net you the gearbox (if your going for 6sp).
Sorted the cert? deal with that after the swap....
and again, if you change the suspension (entire unit's), you require a cert... and winding up boost will shorten the life on an UNTUNED engine, det kills an engine, maybe your thinking about rotors ;) hahaha.
but as jebus said, do some research first ^-^
CozmoNz
Thanks HEAAAPssss
Postby Primo » Thu Aug 25, 2005 11:57 pm
Thankx Heapss
I understand the way of doin this and made my self very clear because of ur helps
1. I need cert for my Engine Swap + brack upgrad and suspension
2. It will need 4efte or 4age with Year 92-96 fxgt gerbox for under 400~600 bux
3. If im goin for 4efte it will be much less work than 4age rite?
4. I feel like 4efte is better optioni and to wind up the boost by boost controler by changin pressure on waste gate i will need better internals?
or i don need huge change???
5. if boost were nomal on 4efte it is slower than 4age if it goes in to rolla b cos of the weight
6. Thankx very much for u guyz helps I appreciate a lot and i just need to buy 4efte i guess :) any one selling one? with ger box + ecu + cooler and radiator + etc
Primo
Postby CozmoNz » Fri Aug 26, 2005 12:08 am
1. Yeap, even changing engine will probbaly count as a 20% power increase
2. just dont worry about the 4age, not worth it, just go 4efte
3. Yup, Bolt in, just wiring, fuel lines, yada yada. no actual engine mounting problems (yucky)
4. nah, just dont get to silly. Ive seen vids of these engiens stock as a bone running 20+psi, and handeling it nicely. But 14odd psi would be more than good enough for plenty of fun.
5. have a look around ^_^ they are getting more and more common.
CozmoNz
Postby gurutasker » Fri Aug 26, 2005 2:20 am
Keep an eye out for someone wrecking a GT starlet aswell...
I was told there was possibly going to be an issue of the gearbox mountings and also if there was room for it? Just get some measurements and things etc. and work it all out.
gurutasker
Postby Nuty|Mike » Fri Aug 26, 2005 8:43 am
or even better look on trademe for a ep82 for cheap cheap smashed up ect then u have everything u need .
I got a ee90 w/4age and im glad i didnt do the conversion looked a mission but the only difference being drivers side mount shifted.
Certs ... my mate just got his cert done on his s1 rx7 with 13bt with upgraded brakes and it cost him around 450 it really depends how long mr engineer takes to do it .
05 Mazda Verisa .....for the Family
Nuty|Mike
Thnks
Postby Primo » Sat Aug 27, 2005 6:53 pm
I asked the guy again and he was talking about 16v not 20v and he said it will bolt staight on
I have a quesition that wheater 20v and 16v CV is in same plac
and also im putting gearbox with it so i dunno.,.
Another question if i get gearbox n engine out from starlet gt would gearbox will fit easily??
And gruntposter i red the post how the guy juiced out 145hp out from ee90 does any one know how to make that happen what to put in????
Primo
Re: Thnks
Postby CozmoNz » Sat Aug 27, 2005 7:16 pm
Primo wrote:I asked the guy again and he was talking about 16v not 20v and he said it will bolt staight on
4age is a 4age, thus why a 20v will bolt into an ae86 when it comes factory with a 16v (bar the dizzy problem)
Primo wrote:I have a quesition that wheater 20v and 16v CV is in same plac
The CV joints will always be in the same place on a fwd... on the half shafts.. between the gaerbox and the hubs lol, where else can they be?
Primo wrote:and also im putting gearbox with it so i dunno.,.
Youll need a gearbox.. or it wont go, but firstly, chosen which engine? 4efte gearbox wont fit a 4age.
Primo wrote:Another question if i get gearbox n engine out from starlet gt would gearbox will fit easily??
its gonna fit, only problem i can imagine you having is the mounts used (possibly need 2e mount from your tranny to fit 4efte, but im not completely sure).
Primo wrote:And gruntposter i red the post how the guy juiced out 145hp out from ee90 does any one know how to make that happen what to put in????
Eerm, he said what he did didnt he?
CozmoNz
Postby QikStarlie » Sat Aug 27, 2005 7:20 pm
you can use the standard box with the 4e, but wont last if your a rapsit
QikStarlie
Sorry I havent made my self clear
Postby Primo » Sat Aug 27, 2005 7:52 pm
Sorry i haven made my self clear
When im swaping the engine i will change the box with the engine that comes with
so is the 4efte gearbox doesn bolt on rite?
Primo
Re: Sorry I havent made my self clear
Postby CozmoNz » Sat Aug 27, 2005 7:57 pm
Primo wrote:so is the 4efte gearbox doesn bolt on rite?
QikStarlie wrote:you can use the standard box with the 4e, but wont last if your a rapsit
2e box will fit the 4e, but it will be munched fairly easily if your not nice to it.
also, you know youll need new fuel lines? use the carbie original line as a return, and get new ones made up.
CozmoNz
well i like the one that comes with
Postby Primo » Sat Aug 27, 2005 8:12 pm
well i like to fit 4efte gear box because i will b reving more than 4000 for first few days or week lol so.. is it hart to put in then???? and also about the fuel system do i put new fuel rail??? woudn it come with the engine
if its not i searched few and come up with in need vl commy fuel pump + fuel lining and i need something that i dunno for return!! Help me Plz
Thanks heaps for CozmoNz
Primo
