APEXI safc blacktop 4age question
Postby RAZA » Wed Aug 24, 2005 1:20 pm
Does anyone have any experience hooking an apexi safc 2 up to a blacktop 20v 4age?
Are there any gains to be had?
Is it an alternative to an aftermarket ecu if you are looking to turbo an n/a engine?
Does it work OK with a map sensor or does it need an afm?
Also does anyone know whether a vafc 2 can be used to control vvt in the same way it controls vtec?
Thanks.
Currently driving:
BMW 135i M
RAZA
Re: APEXI safc blacktop 4age question
Postby Otomo » Sat Aug 27, 2005 1:25 am
RAZA wrote:Does anyone have any experience hooking an apexi safc 2 up to a blacktop 20v 4age?
Thanks.
There will be gains, but I guess don't expect it to be much. You won't really reduce your 1/4mile time by more than 1/10ths of a second. If you do, then you are lucky.
It's (SAFC) not really an alternative to an aftermarket ECU for a turbo...all this does is add or reduce fuel at a certain rpm.
As for the VAFC, I'm not really sure....but I'm guessing that the answer is No.
Waaaaaaaahhhhhh!!!! PANG! PANG! PANG! BOOOOOM!!!
Otomo
Postby ChaosAD » Sat Aug 27, 2005 8:20 pm
It should be able to change the vvt point. works with both map and afm.
ChaosAD
Postby CozmoNz » Sat Aug 27, 2005 8:29 pm
Why go backwards in time, the stock setting is set with TPS and RPM, unlike Vtec which is 1 set point.
setting it so it changes at 1 point (be higher or low if say you ran at full throttle throughout entire rpm range), is taking a step backwards.
its like turning VVT-I into VVT....
Rayne For President!
CozmoNz
Postby ROBODISCO_20v » Sun Aug 28, 2005 1:18 pm
Thanks.
Apexi SAFC2 gives you 12 points across the rpm range that you can adjust the fuel upto -50/+50%, you can set the increments as small as 200rpm. I have just bought one for my levin. I haven't installed it yet but will keep you informed on the results.
ROBODISCO_20v
Postby RAZA » Sun Aug 28, 2005 10:43 pm
ROBODISCO_20v wrote:Apexi SAFC2 gives you 12 points across the rpm range that you can adjust the fuel upto -50/+50%, you can set the increments as small as 200rpm. I have just bought one for my levin. I haven't installed it yet but will keep you informed on the results.
thanks - be interested to hear how you get on.
Currently driving:
BMW 135i M
RAZA
Postby TWSTD » Mon Aug 29, 2005 4:53 pm
RAZA wrote:Is it an alternative to an aftermarket ecu if you are looking to turbo an n/a engine?.
Definitely not. Be aware that it may allow you to adjust fuel, but if you are thinking about installing larger injectors and then trimming them back with an SAFC then you will most likely run into very real detonation issues as the SAFC cannot correct for the resultant shift in the ignition map that occurs when you trim fuel back in this way. This is NOT what you want to do with a NA -> turbo conversion! I would reccommend something like a Greddy E-manage as an alternative thats not really much more expensive.
We sell these and can offer a TS discount - contact me off-list if you want more info.
AL
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby 1598cc » Tue Aug 30, 2005 9:56 am
e manage.. isnt that still a piggyback? .
1598cc
Postby TWSTD » Tue Aug 30, 2005 1:31 pm
1598cc wrote:e manage.. isnt that still a piggyback? .
Yes - but whats your point?
Click here!
TWSTD
Postby ChaosAD » Tue Aug 30, 2005 7:33 pm
Doesnt emanage only adjust +/- 20%? Safc is limited enough with its 50%
ChaosAD
Postby TWSTD » Tue Aug 30, 2005 8:48 pm
ChaosAD wrote:Doesnt emanage only adjust +/- 20%? Safc is limited enough with its 50%
Errrr no - not at all. If you only own the main unit and use it as a stand alone intercept then yes, but there is no sensible reason to do so when with the addition of the ignition and injector harnesses you have a fully laptop tunable 20x20 resolution ignition AND fuel computer. FYI we are running the newer emanage ultimate in the caldina (making 214kw at the wheels on moderate boost and standard internals). The E-manage is a FAR sight above a simple fuel controller like the S-AFC.
Click here!
TWSTD
