Mmm, Boost wrote:
Thing is, you'd notice 3/8ths of $&#$% difference in an NA car, and more than likely would actually lose power, as it burns so much slower.
Mr Revhead wrote:that FIA stuff sure stinks though!
and is not kind to seals and orings
Leon wrote:Try being stuck in the Sky City carpark with all the cars queued up (idling) when they left in the mornings. I was there as a scrutineer, and I tell ya, I wasn't feeling too flash after a couple of hours of those fumes.
i beg to differ. i had a heap of WRC control fuel and it makes a huge difference in a N/A engine ,possibly 15% maybe more power.
Mmm, Boost wrote: I'd be very surprised if adding just race fuel gained you 15% power,.
Mmm, Boost wrote: unless you had very high compression and/or lots of advance.
fangsport wrote:Mmm, Boost wrote: I'd be very surprised if adding just race fuel gained you 15% power,.
the rally guys reckon that with the right program for the ecu, there can be an increase of up to 70hp in a group N car using the control fuel.
bit of both. bear in mind the old engine wasn't huge in power and was tired, but this fuel and a big carb and i reckon it was close to double at the wheels.
unfortunately ,one didn't check the fuel union on the carb, and an inferno followed.
Mmm, Boost wrote: Again, its hardly fair to compare a race motor to your average guy on the street...I know on the right application race fuel makes a big difference, but if I were to chuck some into the wagon, it'd do jack for it.
Mmm, Boost wrote:But thats not just adding control fuel now is it
caldinagtt wrote:look at brett lee sangs evo 2 in the latest performance car rs on pump gas 23psi 340kws at the wheels and on c16 373 kw on 23psi atw now thats a big differnce so you do deinatly get a power gain.
CozmoNz wrote:and how much of a timing increase?
