Caldina 110v AC power outlet - anyones work?
Postby TWSTD » Mon Sep 19, 2005 12:25 pm
Has anyone managed to get the 110v AC power supply working in the caldina? I assume all ST215's come with them - plug is located near rear seat ash tray. Ive trued runnign a laptop powersupply off mine but no go...
would be very useful though if i could get it going!
AL
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby AJz » Mon Sep 19, 2005 12:34 pm
really, i didnt know caldinas had such a thing..... 8O
110V wont power your power supply, NZ is 240V member, unless its a US laptop.
I had vtax :(
AJz
Postby fuel » Mon Sep 19, 2005 12:37 pm
AJz wrote:really, i didnt know caldinas had such a thing..... 8O
Some laptops have auto-voltage. My monitor for instance runs on 110V right up to 240V.
LOUD NOISES!!!
fuel
Postby AJz » Mon Sep 19, 2005 12:39 pm
true,
you would wanna check the laptop first tho.
Anyone got a pic of this powersupply, i didnt even know caldinas had them till just before. Not a silly idea i suppose.
I had vtax :(
AJz
Postby TWSTD » Mon Sep 19, 2005 12:53 pm
AJz wrote:you would wanna check the laptop first tho.
Its the powersupply that you would need to check, not the laptop - and yes mine is 110-230v as are many (most?) laptop power supplies :-)
Click here!
TWSTD
Postby fivebob » Mon Sep 19, 2005 1:16 pm
You will probably find that the output is square wave or modified sine wave, and your power supply may not work as the voltage peaks may be lower than it requires.
Postby AJz » Mon Sep 19, 2005 1:34 pm
i just woke up, you know wat i ment, lol
I had vtax :(
AJz
Postby Malcolm » Mon Sep 19, 2005 1:57 pm
fivebob wrote:You will probably find that the output is square wave or modified sine wave, and your power supply may not work as the voltage peaks may be lower than it requires.
I agree that it probably runs a modified sine wave, as a pure sine wave inverter is pretty expensive, but a simple power supply for a laptop, which just rectifies back to DC, shouldn't have any problems with it provided the output from the inverter is a true 110VRMS.
Infact when you think about it, it seems kind of silly going from DC (car supply) -> AC -> DC to charge your laptop, you could easily build a voltage regulator circuit (or buy a pre-made one) provided the required voltage for charging the laptop is less than about 13VDC, and it will be more efficient than running through 2 wave converters.
I guess that doesn't answer the question of whether the outlet works though...
Postby fivebob » Mon Sep 19, 2005 2:03 pm
Bit of a problem when your laptop runs 20v :(
From what I could find, transformers are more likely to have problems, due to the voltage peaks being lower than expected.
BTW I think the switch says 100v so maybe it's too low anyway.
Postby Santa'sBoostinSleigh » Mon Sep 19, 2005 2:39 pm
i cant say ive check the 110V plug, but my 12V rear plug goes.
however the button must be pushed in and the car must be in the 'on' position (eg it dont go in the 'acc' position on the ignition)
/me adds "shove multimeter into 110V socket on the caldina" to the TO DO: list
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby HERGTT » Mon Sep 19, 2005 6:06 pm
Santa'sBoostinSleigh wrote:i cant say ive check the 110V plug, but my 12V rear plug goes.
Yeah we run the playstation, laptop,etc off the rear (boot) plug, but don't think we have tried the one by the rear seats...adding to our list too :D
HERGTT
Postby rodstr » Mon Sep 19, 2005 6:36 pm
i ran a fone charger at the back of where TWSTD said, it seemed to charge my fone alright... but u have to check the wattage of what your laptop wants, the car outputs 50va? does it support 50va?
rodstr
Postby Santa'sBoostinSleigh » Tue Sep 20, 2005 9:25 am
it is 100v, remembered to have a look at the switch this morning, but havent tested it yet
Santa's Mega Sale
Postby XERO » Tue Sep 20, 2005 10:19 pm
I need some thing to check it with... i know if i hit that switch, it lights up...
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Santa'sBoostinSleigh » Tue Sep 20, 2005 10:22 pm
XERO wrote:I need some thing to check it with... i know if i hit that switch, it lights up...
2 bits of wire and ya tounge ;)
Santa's Mega Sale
Postby TWSTD » Tue Sep 20, 2005 11:19 pm
Santa'sBoostinSleigh wrote:2 bits of wire and ya tounge ;)
Please dont get drunk and do that Mark....
Click here!
TWSTD
Postby Santa'sBoostinSleigh » Tue Sep 20, 2005 11:25 pm
PLEASE PLEASE PLEASE Please dont get drunk and do that Mark....
Santa's Mega Sale
Postby XERO » Fri Sep 23, 2005 11:22 am
Owww my hung... haha
XERO
110v power supply button
Postby PhilSawtell » Wed Jan 11, 2006 4:24 pm
there should be a button on the left side of your steering wheel on the dash that turns it on or off when the lights on your supply is on it also works for the 12v supply in the boot
PhilSawtell
