best gze to turbo
best gze to turbo
Postby scope » Sun Sep 25, 2005 10:46 pm
hi
i've read on here that there are two types of 4agzes (one being map, other afm) and i've also heard that one runs compression ratio of 8.0:1 and other 8.9:1 (please correct me if i'm getting something wrong along the way)
i'm wanting to convert a 4agze to turbo but i am unsure what one would be best so i have questions:
1) is the 8.0:1 gze map or afm?
2) which is better for turboing? map/afm?
i'm wanting to run around 15-20psi on standard internals, possibly using some type of link computer in the future (haven't really thought that far..)
thanks for any help
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby crnkin » Sun Sep 25, 2005 11:08 pm
The early one is map, the late one is map, but I forget if early is 8.0:1? i think its 8.0:1 anywhos
The best to turbo is much of a muchness, but when you think bout it you get more power at the same boost on a higher comp and the 8.9 will easily take 20psi, so yeah
but map has less restriction for lower boost....
(im running high comp at 25psi, so im a bit biased, but go for high comp :) )
deaf_homo "currrently yes"
crnkin
Postby scope » Sun Sep 25, 2005 11:11 pm
crnkin wrote:The early one is map, the late one is map
oh real :lol:, i'll take a guess that the later one is afm?
scope
Postby rage » Sun Sep 25, 2005 11:22 pm
one has issues with the ecu losing power at about 5500rpm
do a search.
rage
Postby crnkin » Sun Sep 25, 2005 11:28 pm
hehe afm, sorry bro im doing an assignment due tomorrow hehe
crnkin
GRRRRRRRRRR i mean late is afm
AFM is the one which looses power about 5500 rpm i think but thats with the sc12 on it
crnkin
Postby scope » Sun Sep 25, 2005 11:29 pm
rage wrote:do a search.
if people would sticky good posts then people like you would have to stop saying "do a search" as when you search (as i did) there were 279 posts to go through and as you might imagine it wouldn't be hard to accidently slip past the one that answered my questions?
scope
Postby scope » Sun Sep 25, 2005 11:30 pm
crnkin wrote:GRRRRRRRRRR i mean late is afm
thanks :D
scope
Postby pidge » Sun Sep 25, 2005 11:43 pm
Early is AFM, late is MAP.
from club4ag
AW11 was AFM + dizzy ignition, 8:1 CR, no oil squirters
AE92 88-90 was AFM + DLI, 8:1 CR, no oil squirters
AE92 90-91 was MAP + DLI, 8.9:1 CR, oil squirters, smaller SC pulley
AE101 was MAP + DLI, 8.9:1 CR, oil squirters, smaller SC pulley, lightened conrods (apparently), snap ring pistons.
AE101 and late AE92 had the hotly-debated-as-to-what-the-hell-they-mean-by "semi-forged" coated pistons
The best bottom end and pistons are in the AE101.
If you want AFM, you would be best to take the early AE92 one, as it has DLI, unless you really want oil squirters and AFM, in which case you would need the early AE92 engine, but swap in any of the AE92 (late), or AE101 4AGZE blocks.
If you are going for an after market ECU, just use the AE101 or late AE92 engine with a MAP ECU.
pidge
Postby Crucible » Mon Sep 26, 2005 12:49 am
rage wrote:one has issues with the ecu losing power at about 5500rpm
do a search.
My Truenos ae101 Map, and its definately got that problem!...... Bugger :cry:
Turbo + 4AGZE = Bazda or Evlgtz :D
Crucible
Real Life Mechanic
Postby matt dunn » Mon Sep 26, 2005 1:05 am
thanks :D
Yes Thanks,
but both pieces of your information are wrong.
The early are AFM, the later ones are Map,
and it's the map one's that loose the power.
Postby Malcolm » Mon Sep 26, 2005 1:44 am
pidge wrote:AE101 and late AE92 had the hotly-debated-as-to-what-the-hell-they-mean-by "semi-forged" coated pistons
I think the common sense answer to that is that they're semi-solid forged, which means they'd be less work-hardened than forged pistons (ie softer), but still with a superior grain structure than cast and machined or plain cast pistons.
Postby EVLGTZ » Mon Sep 26, 2005 8:55 am
nope thats the MAP version on both accounts. And power drop is still there with turbo setup unless using an aftermarket ecu or ya get around it using other methods.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby EVLGTZ » Mon Sep 26, 2005 8:57 am
whoops should of read entire post before posting hehe :oops:
EVLGTZ
EVLGTZ
Postby Caveman » Mon Sep 26, 2005 9:24 am
All of them are good for turbo.
AFM is the one that doesn't loose power as already stated.
The early ones have pathetic manifolds and plemuns and should be replaced with bigport or small port manifolds (depending on which 4agze you have), plemuns and throttle bodies if going turbo. The reason they are so crap is the sc is in the way and theres very little room.
Caveman
Postby crnkin » Mon Sep 26, 2005 10:17 am
thanks :D
Yes Thanks,
DOH
ah well shit happens im so tired. long nite!
(and i was sure grotty's ae101 has afm....)
crnkin
Postby crnkin » Mon Sep 26, 2005 10:34 am
pidge wrote:AE101 was MAP + DLI, 8.9:1 CR, oil squirters, smaller SC pulley, lightened conrods (apparently), snap ring pistons.
ae101 definitely has tiny conrods. And is has "semi forged pistons" how on earth is that better to turbo than a lower comp (i like higher tho!) fully forged piston, bigger rod'ed early model block???
I reckon run the high comp pistons (late) with the early model mega rods, for ultimate reliability that is, and the secret is-
redtop same as early model (non tvis but the tvis ones are way better than late models anyways)
and late model are same as silvertop. Although i have both sets and the part number is one digit different (ze ends in a 1, silvertop ends in a 2)
crnkin
Postby Bazda » Mon Sep 26, 2005 10:38 pm
late model ae92 redtop has the big rods, so to the ae101 (not the gze) have the big rods as well. The rest are smaller. I'm pretty sure thats how it goes.
I jsut recon you run 25psi on high compression you will start having reliablity problems, head warp etc.
Postby vvega » Mon Sep 26, 2005 10:47 pm
this eould have to be one of the most ful of shit threeds ive read in a while
v
vvega
Postby vvega » Mon Sep 26, 2005 10:53 pm
the 101 comes with the large rods
the 101 facelift has the n/a rods
all the gze's have hyperutectic pistons
they all have the same crank
the 101's have the oil squirters
only the first aw11(excluding facelift)snd the ae-92 gtz is afm(i think) the rest are all map
smaller rods do not mean there weaker
lower compresson is not always better
and finally
toyspeed is not the place to come for engine building advice
unless you just wanna blow shit up.............
v
vvega
