removing outer cv joint - ee80
Postby EVL20V » Tue Sep 27, 2005 9:03 pm
am going to attempt to take out the front right outer cv joint on an ee80 85 corolla sedan, shouldnt b much difrent from ae82 etc. anyone got general tips or advice? :roll: :lol:
EVL20V
Postby Lloyd » Tue Sep 27, 2005 9:16 pm
Know someone with a slide hammer :)
Not really too hard, but you may have issues getting the nut off the CV if its on really tight. May also have issues getting the CV back onto the shaft in some cases as those clips can be a right c*nt.
Basically, remove wheel, CV nut, lower ball joint (by the nut on the joint or the 3ish bolts underneath holding the ball joint on the lower arm), swing the hub out of the way, cut the boot off, bash with a hammer/slide hammer.
Postby Rob » Wed Sep 28, 2005 1:40 pm
Toyota cv's can be real bastards. Sometimes you need to put them in a vice. You put the shaft in the jaws of the vice with the half the joint sitting hard against the end of the jaw. Hit the top as hard as you can and it should pop off (get someone to catch as they can fly some way)
Use this only if it won't come off in place :wink:
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Ae92typeX » Thu Sep 29, 2005 12:32 am
and wear safety glasses when doing the vice bash way.
even though I rarely wear then (never learn my lessons) Ive seen some nasty injuries from the occasional one shattering.
For toyota ones ive usually found it faster to take the shaft out and easier to remove the inner joint and slide the boot up the shaft.
edit: god knows why I thought you were just replacing the boot and not the cv as stated. Im going to bed.
Ae92typeX
