My OEL has a line through it!
Postby Blackrazor » Fri Sep 30, 2005 8:12 pm
I would be very surprised if it wast a problem with the headunit internally. The only other things that would cause it other than, say, an OEL inverter fault, would be impact damage, or a corroded contact on the faceplate or unit :)
Boring Sig
Blackrazor
Postby pervert » Fri Sep 30, 2005 8:35 pm
Blackrazor wrote:or a corroded contact on the faceplate or unit :)
That's my educated guess... 8)
pervert
Postby GGnz » Tue Oct 11, 2005 10:52 pm
Fixed. Believe it or not it was some magical wire. I was working on some guages today and used the stereo battery, ground, and parklights wires which require me re-doing the wiring. I guessing it was the ground so the HU aint putting out weird noises as well now.
Things are looking up :D.
GGnz
Postby Vertigo » Thu Nov 24, 2005 6:16 pm
this ggnz is a lol c**t
TVIS just kicked in, yo!
Vertigo
