ke30 3tgte - engine mounts
Postby keseventy » Mon Oct 03, 2005 9:39 pm
ive found some ta22 2t mounts but do i need the rubber mounts with the stud on either side or the metal bracket that originally bolts onto the 2T engine block?
1977 ke30
keseventy
Postby wde_bdy » Mon Oct 03, 2005 10:37 pm
You need to mod your crossmember, do a search.
wde_bdy
Postby keseventy » Mon Oct 03, 2005 10:49 pm
ive read that the mounts bolt to the k series crossmember. no?
1977 ke30
keseventy
Postby wde_bdy » Mon Oct 03, 2005 11:02 pm
They don't line up properly and the oil drain from the turbo does not suit the TA22 mounts.
Callum
wde_bdy
Postby YeMs » Tue Oct 04, 2005 8:35 pm
bolted straight into my crossmember. but as mentioned the oil drain is abit of an issue. i actually got 1 custom made (bit of a bitch) u would b better off to block the factory oil return and but a plug into the sump like how they setup the oil return on the 4age turbo's.
Your local Hybrid Elite tech
YeMs
