pyro_sniper2002 wrote:Solvent N will do it the quickest, BUT make damn sure you get it all off otherwise it will melt the plastic.
pervert wrote:Mineral Turpentine works best, available for about $4 at any supermarket...
Meths also works, but not as quickly...
rdav wrote:can also use Meguiars PlastiX b4 or after you have used the solvent, I had white paint on a tail light and it took it right off, will remove any swirl marks and light scratches, and makes any clear plastic well "clear" Works on the plastic speedo housing as well. Makes em look better then new.
pervert wrote:I know Jiff works for taking yellow headlights back to clear...
I'm all about just using household products...haha...
EVL GSXR wrote:pervert wrote:I know Jiff works for taking yellow headlights back to clear...
Geez Perv sound's like you got the house hold product's down..
Your mrs don't make you wear a appron and stuff when you doing the house work as well aye![]()
