Inserts
Inserts
Postby RE20 » Wed Oct 12, 2005 2:23 pm
Can someone please tell me if shock inserts affect the captiveness of a spring? Im gonna replace my oil ones with kyb gas inserts but the insert length would depend on the springs I use wouldnt it? Or do I have it wrong? Its got standards at the moment, but I wanna lower it , and when I do I dont wanna have to buy inserts again . So should I put choppys in when I get them replaced? or will it be sweet? Hope that makes sense!
In the event of nuclear catastrophe, the only survivors will be Cockroaches and Toyota K series engines...
pervert wrote:Haha, it's not low enough, it still has suspension travel!!!
RE20
Postby fangsport » Wed Oct 12, 2005 4:44 pm
the length of the insert with effect the ability to keep it captive. short springs with long shocks will root the valves in the shocks due to bottoming out.
have a search or go to your supplier to see if ther are shocks of the same diameter put shorter in length, then fit a spacer in the strut to stop the insert from moving inside the strut.
fangsport
