Turbo 4agte , what size injectors should i use ?
Postby Charged1 » Sun Oct 16, 2005 7:21 pm
Hello what would be the best size injectors to use on my turboed 4agze , and can you get some that will slot straight in , also is it a good idea to change the fuel pump ? Thanks in advance
Charged1
Postby EVLGTZ » Sun Oct 16, 2005 8:31 pm
The std injectors and pump are good for at least 170kw at the wheels.
If going to upgrade then some 440s or 550s be the way to go.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby flygt4 » Sun Oct 16, 2005 9:07 pm
my current injectors are about standard size and were at 95% at 174kw atw. i believe 440's will stretch to just over 200kw atw.
a set of 550's out of a us market 2jzgte or latemodel 3sgte will leave you plenty of headroom and probly be capable of more than you'd ever need. . i had my set tested and they actually flowed 500cc@44psi.
flygt4
Postby matt dunn » Mon Oct 17, 2005 10:52 pm
flygt4 wrote:my current injectors are about standard size and were at 95% at 174kw atw. i believe 440's will stretch to just over 200kw atw.
I made 204 atw with injectors that flowed 410cc.
I now have a set of the USA 2JZGTE 550's and mine flowed 560cc at 3 bar or 45psi?
Matt
Postby 1598cc » Tue Oct 18, 2005 9:42 am
stock injectors till 12psi, extra injectors to 20.. thats what i ran. ruff but works well.
1598cc
Postby matt dunn » Tue Oct 18, 2005 12:25 pm
The 440's I've flowed actually flowed 500cc at 45 psi so they are not that far behind.
Postby flygt4 » Tue Oct 18, 2005 5:40 pm
fro memory there was someone else who had a set of 3sgte 540's flowed at 500 odd cc@44psi. could be luck of the draw? or the export supra ones could be slightly different than gen4 3sgte ones. *shrug*
flygt4
Postby Akane » Tue Oct 18, 2005 7:33 pm
I have a set of 440's for sale, if you want them PM me, $150.
Postby matt dunn » Tue Oct 18, 2005 9:44 pm
flygt4 wrote:fro memory there was someone else who had a set of 3sgte 540's flowed at 500 odd cc@44psi. could be luck of the draw? or the export supra ones could be slightly different than gen4 3sgte ones. *shrug*
What colour are they?
The 440's I have are grey,
and the 550's are blue/green color.
Matt
Postby Lloyd » Tue Oct 18, 2005 9:54 pm
My 365s flowed a touch over 400 on 45psi. Guess its luck of the draw aye Bazda ;)
Postby flygt4 » Wed Oct 19, 2005 5:07 pm
matt dunn wrote:What colour are they?
Matt
umm ones that flowed at 500 are red
flygt4
Postby matt dunn » Wed Oct 19, 2005 5:29 pm
Matt
well there's obviously a few different types then.......
Postby flygt4 » Wed Oct 19, 2005 7:16 pm
yeah thats my thinking. these definately came out of a gen 3 or 4 sw20.
flygt4
Postby Bazda » Thu Oct 20, 2005 4:26 pm
HRT wrote:My 365s flowed a touch over 400 on 45psi. Guess its luck of the draw aye Bazda ;)
HUH??
Postby Lloyd » Thu Oct 20, 2005 5:58 pm
Didn't your standard ones kinda max out a bit early and melt stuff?
Postby Bazda » Thu Oct 20, 2005 6:08 pm
mined maxed out on 12psi, I even got mine flowed and cleaned 8O.
IH8TEC has doen hsi conversion and his also maxed out on the same boost.
i suppose the afm version has crappier injectors or something...
FYADUP jsut had his re-dynoed and his also maxed out on 12psi with 173kws on the standard map ecu, when he had shitty manifolds he was running 15psi easy but with only 152kws.
so it seems the flow of your manifolds makes a difference.
Postby matt dunn » Thu Oct 20, 2005 6:48 pm
HUH??
lol,
youre not reading that as 45psi boost are ya?
That's 400cc min inj flow rate at 45 psi fuel pressure
Postby Bazda » Thu Oct 20, 2005 6:50 pm
matt dunn wrote:
HUH??
lol,
nah i didnt know why he said my name.
Postby flygt4 » Fri Oct 21, 2005 7:45 am
Bazda wrote:FYADUP jsut had his re-dynoed and his also maxed out on 12psi with 173kws on the standard map ecu, when he had shitty manifolds he was running 15psi easy but with only 152kws.
that would seem consistant with mine maxing out at 174kw , although i was at 15psi on a slightly smaller turbo. interesting point about the effect the manifold has too
flygt4
Postby FYADUP » Fri Oct 21, 2005 10:42 am
LOL, i thought i'd join the party guys. cheers bazz, well they didnt max out, thats just wat i ran it on, just only played with it a little on ther mway before i got to Torque. Could have run about 13, well ran 13.3 on first dyno. I just couldnt get the turns on my boost tap right! :D:D Also yer true, on my old setup it would spike tro 15 every now and then, but wouldnt cut! Well i dunno wata do now, as ill prob never see that setup again.... or that mean manifold, so i dunno wata do now!
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
