bluemaumau wrote:i gotta limited budget.
bluemaumau wrote: cant you just chip them?
bluemaumau wrote:how much would a aftermarket one be?
Akane wrote:looks like you can't afford to run with the big boys yet, so why don't you just lay low for now and drive a Honda?
bluemaumau wrote:for a turbo blacktop with ze internals wat would be the better computer? i was thinkn the ze one because its already forced induction...
wat do you think?
pidge wrote:You can run on the 4AGZE MAP ECU, but there's the power dip at 5500 rpm as the ECU dumps fuel into the engine, and it's only got the fuel and spark maps for up to 15psi.
If you are happy with those limitations, use the ZE ECU.
If not, you are looking at the cost of an Aftermarket ECU, Installation and tuning.
pidge wrote:bluemaumau wrote:for a turbo blacktop with ze internals wat would be the better computer? i was thinkn the ze one because its already forced induction...
wat do you think?
Akane wrote:Aftermarket? What brand of aftermarket ECU can I buy with a paperclip and 2 cents?
