7m Q
7m Q
Postby KE20 » Mon Oct 24, 2005 1:02 pm
can some one tell me: is the crank(where the fly bolts on) level with the block??
or does the crank stickout further than the block?? or otherway?? if so measurements please.
or if someone aucks has one out with the fly off can i come have a look??
mark
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Re: 7m Q
Postby Toymad » Mon Oct 24, 2005 6:29 pm
KE20 wrote:can some one tell me: is the crank(where the fly bolts on) level with the block??
mark
The end of the crank is slightly proud of the rear seal. I don't have a pic of one with a flywheel but I have a 5M (same engine series) with a flex plate and you can see enough.
PM me if you want pics and I will see what I can do.....
Toymad
