Whats The problem guys?
Postby zshahz » Sat Oct 22, 2005 1:09 pm
I have a corolla AE92 '87 manual..
sometimes when its on nuetral, the revs go up and down. What could be the issue here?
zshahz
Postby CozmoNz » Sat Oct 22, 2005 1:37 pm
Does it have a idle stepper motor?
also could be a vac leak...
Rayne For President!
CozmoNz
Postby Skidman » Sat Oct 22, 2005 1:46 pm
How quickly?
When cold is it more noticable?
Hondas are made for people who dont know better.
Skidman
Postby fangsport » Sat Oct 22, 2005 5:43 pm
does it have a full compliment of coolant??
fangsport
Postby zshahz » Mon Oct 24, 2005 10:13 am
whats a idol stepper motor? ill try to see if it happens when its cold and get back to you guys.
zshahz
Postby Dragger_Dan » Mon Oct 24, 2005 1:46 pm
fangsport wrote:does it have a full compliment of coolant??
This is the most likely explanation. Try burping the cooling system.
Dragger_Dan
Postby fangsport » Mon Oct 24, 2005 1:55 pm
don't you mean 'purging'??
if the 2 temp sensors arn't constantly on coolant, they will give dodgy signals to the ECU.
fangsport
Postby Dragger_Dan » Mon Oct 24, 2005 5:34 pm
I ment burping as in getting all the air out, if there are air bubbles in the system.
Dragger_Dan
Postby Skidman » Mon Oct 24, 2005 7:02 pm
Im not getting smart, only curoius, how would lack of coolent effect the engine in this way? Why would the ecu's failsafe do this for high temp? wouldnt the temp gague in the dash be reading way high beacause of the steam?
Skidman
Postby fangsport » Mon Oct 24, 2005 7:22 pm
Skidman wrote:Im not getting smart, only curoius, how would lack of coolent effect the engine in this way? Why would the ecu's failsafe do this for high temp? wouldnt the temp gague in the dash be reading way high beacause of the steam?
the sensors give the ecu certain values at consistant levels/ temperatures, if the coolant level is a bit low, the signal will be intermittant , as it won't be consistantly immersed, it will only be getting washed by the passing coolant.
steam, not being a liquid, usually won't give a reading on a temperature gauge, unless it has super-heated the passing water(if the water level is high enough ) i.e blown H/Gasket.
fangsport
Postby Skidman » Mon Oct 24, 2005 8:06 pm
K, so your sayin that it thinks that its going between cold start and normal running temp?
Wouldnt the ecu have parameters that have a time worked into them, so the ecu can tell that its a fault?
Also the temp sensors dont care about being in water or not, they just go off heat. I didnt think that they had a level sensor either?
Im still lost (call me stupid if you like, but this just dosnt make any sense to me at all)
Skidman
Postby fangsport » Mon Oct 24, 2005 8:20 pm
here is an example of a failure.
my old van was getting a wee bit hot (according to the guage), it then went back to normal (no worries i thought, stuck thermostat), it then went to nothing and was really hot ( as in in the cabin).
the H/G went, pressureised/heated the cooling system(high guage reading).the top radiator hose opened up like a zip chucking most of the water out( low reading). what was left in the system quickly turned to steam (high cabin temp).
most temp sensors will only work in water, until the surrounding metal gets so friggin hot, that the sensor itself cooks.
fangsport
Postby Skidman » Mon Oct 24, 2005 8:38 pm
Yep but thats when all the water is lost not just an air pocket...
All of the cars that have had an air pocket that i have had to purge out have shown it by the temp gague sailling right up to the big 'H' and i have never seen a car that has the described problem that has been fixed by simply purging the system.
Plus if the system was doing that, reading cold, then hot, seem as the ecu temp sensor is right next to the temp gague sensor wouldnt you see the temp gague going in-sync with the high/low idle???
Skidman
Postby Skidman » Mon Oct 24, 2005 8:58 pm
Check the coolent just incase. Nobodies perfect i could be wrong.
Carring on with the diognosis, dose it have a digital or an analog TPS?
If it has an digital TPS check that its not been tampered with, cause they usualy only sensor idle and wide open throttle, and it might be mal-adjusted and not telling the ECU to control idle, (thinking that its not idling when it is.)
They run a vein type AFM aye? (so thats probably alright, they dont usually cause too much hassle, check voltages anyway if in dought)
I take it that its got an oxy sensor...check it on a scope to see how fast its cycling (should be around 8 herts) if you dont have a scope just unplug it and it will go open loop and run ritch.
Check Battery voltage just incase (this has caused problems in the past)
Skidman
Postby fangsport » Mon Oct 24, 2005 10:56 pm
Skidman wrote:Yep but thats when all the water is lost not just an air pocket...
not big on the inner workings of EFI systems, but my old AE92 would get erratic idle, fixed by topping up the coolant. my diagnosis was to do with the 2 sensors on the back of the head, as they are amlost at the highest point of the cooling system. also, top-up has been documented on here before many times before as a cure.
fangsport
Postby spencer » Tue Oct 25, 2005 11:45 am
fangsport wrote:the sensors give the ecu certain values at consistant levels/ temperatures, if the coolant level is a bit low, the signal will be intermittant , as it won't be consistantly immersed, it will only be getting washed by the passing coolant.
The sensor is a basic thermistor a metal that changes resistance with heat. The response time of these things in cars is relatively slow they dont have to react fast. The heat in the alluminium housing they are bolted into will keep them from fluctuating if there is no water flowing past.
spencer
? is it just a faulty idle up.
Postby Frosty » Wed Oct 26, 2005 1:35 am
How much is the idle changing? 1 or 2 hundred rpm?
It may just be a Faulty idle up solinoid for the air-con, charging or other sub system.
Also blockages in the small air gallerys in the throtle body can affect idle speed.
To see if the idle-up solinoids are playing up just un plug them one at a time to see if the idle stabilises.
P.S dont forget to plug them back in or the next time you turn on your lights or air-con at idle the engine could stall (could suck)
Project 73 RT-87 Corona Wagon, 1G-GZE & W55.
Project 67 Anglia Van 1500 & Escort Box.
Beater TT-132 Corona Sedan.
Frosty
Postby zshahz » Wed Oct 26, 2005 8:58 pm
wow.. alot of stuff to take in here fellas!!! i dunno its weird, it happens sometimes then stops, car doesnt have A/C as previous owner took it out. Is there anyone here who is a mechanic and can tell me what the actual problem is if i took it to them? This would be greatly appreciated.
Thanks
zshahz
Postby Skidman » Wed Oct 26, 2005 10:39 pm
Yup, where bouts do you live tho?
Skidman
Postby zshahz » Thu Oct 27, 2005 7:22 pm
fangsport your a bloody legend. Today it was revving up and down hardcore.. was on the northwestern motorway when i saw temperature guage going up.. i took the rosebank exit, pulled up at petrol station and yes water had almost fully run out.. quite lucky here. I re-filled it and since then problem has been fixed.
But i dont understand how this made the revvs flick up and down.. why didnt it happened to my other old car?
skidman im in west auckland... but its all good at the moment.
zshahz
