RomanV wrote:Muahaha, it will be interesting to see how the bunderson will go.![]()
I am assuming that you have a 30 front, 70 rear weight bias?
You have it the other way around on your post.
RomanV wrote:Here is an example of what is required.
Car title/user name: eg. 4k starlet, durty starlet
(Engine info)
Displacement: eg. 1290cc
Engine Location: eg. Front
Type: eg. NA
(at flywheel)Horsepower@RPM eg. 58hp@5200rpm
(at flywheel)Ft-lbs of torque@RPM eg. 67ft-lbs @ 3600rpm
Compression ratio eg. 9:1
Redline RPM: eg. 6000rpm
(drivetrain info)
Gears: Eg. 4 speed
Manual/Auto: eg. manual
Gear ratios (below)
1: 3.789
2:2.220
3: 1.435
4:1
5:0.865
Final drive ratio:4.316
Driving wheels: eg. back
(Chassis and body info)
Car weight in kgs: eg. 782
front/rear weight distribution: eg. no idea
Wheelbase in cms: eg. 230cm.
Tire size: eg. 205/60 R13
Coefficient of drag: eg. no idea
Overall height in cms: eg. 135cm
Overall width in cms: eg. 153cm
Ground clearance in cms: eg. 19.5cm.
