Toyspeed virtual drag race competition. *CLOSED FOR NOW*
Postby Brick » Tue Oct 25, 2005 1:36 pm
well you could try it with that data and see how close it gets wen i do go down the 1/4 hopefully in a couple of weeks
Brick
I know Kung Fu
Postby Jebus » Tue Oct 25, 2005 1:46 pm
Car title/user name: eg. 4AGE KE30/Jebus
(Engine info)
Displacement: 1587cc
Engine Location: Front
Type: eg. NA
(at flywheel)Horsepower@RPM 135hp@6600rpm
(at flywheel)Ft-lbs of torque@RPM 110ft-lbs @ 5200rpm
Compression ratio eg. 9.4:1
Redline RPM: 7800rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.587
2: 2.022
3: 1.384
4: 1.000
5: 0.861
6: N/A
Final drive ratio: 4.1:1
Driving wheels: RWD
(Chassis and body info)
Car weight in kgs: 870kgs.
front/rear weight distribution: ??? Possibly similar to an AE86?
Wheelbase in cms: 233.4cm
Tire size: 195/50 R15
Coefficient of drag: ???
Overall height in cms: 137.4cm
Overall width in cms: 157.0cm
Ground clearance in cms: 10.0cm
Jebus
Postby Dragger_Dan » Tue Oct 25, 2005 2:13 pm
Car title/user name: eg. NA AW11, Dragger Dan
(Engine info)
Displacement: 1598cc
Engine Location: Mid
Type: NA
(at flywheel)Horsepower@RPM 120hp @6600
(at flywheel)Ft-lbs of torque@RPM 102 Ft-lbs@5000
Compression ratio: 9.4:1
Redline RPM: 7500rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.310
4: 0.969
5: 0.815
6: N/A
Final drive ratio: 4.31:1
Driving wheels: RWD
Car weight in kgs: 970kg
front/rear weight distribution: 44.5 / 55.5
Wheelbase in cms: 231.9cm
Tire size: 195/60/14
Coefficient of drag: 0.34
Overall height in cms: 125.0cm
Overall width in cms: 166.6cm
Ground clearance in cms: 12.6cm
Dragger_Dan
Postby boxxy » Tue Oct 25, 2005 2:16 pm
Car title/user name:AE111 Corolla, Boxxy
(Engine info)
Type: NA Screamer Yo
(at flywheel)Horsepower@RPM 170@7800rpm
(at flywheel)Ft-lbs of torque@RPM 161.81 Nm / 5600 rpm
Compression ratio 11:1
Redline RPM: 8000 rpm
(drivetrain info)
Gears: 6 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 2.050
3: 1.481
4: 1.166
5: 0.916
6: 0.725
Final drive ratio: 4.529
Driving wheels: front
Car weight in kgs: 1100kgs.
front/rear weight distribution: 60/40 ??????
Wheelbase in cms: 246cm
Tire size: 215/35/18
Coefficient of drag: ?????????
Overall height in cms: 133cm
Overall width in cms: 169cm
Ground clearance in cms: 12cm
1997 Corolla GT.... AGGGHHHHH too many valves
101.5KW atw :D
"Open your throat, we know you can!"
boxxy
Postby Dragger_Dan » Tue Oct 25, 2005 2:27 pm
Car title/user name: eg. NA AW11 - automatic, Dragger Dan's clone
(Engine info)
Type: NA
(drivetrain info)
Gears: 4 Speed
Manual/Auto: auto
Gear ratios (below)
1: 3.643
2: 2.008
3: 1.296
4: 0.892
5: N/A
6: N/A
Final drive ratio: 3.034
Driving wheels: RWD
Car weight in kgs: 990kg
Tire size: 185/60/14
Dragger_Dan
Postby RedMist » Tue Oct 25, 2005 2:55 pm
Car title/user name: Bunderson, RedMist
(Engine info)
Displacement: 1625cc
Engine Location: Rear
Type: NA
(at flywheel)Horsepower@RPM 211hp@7400rpm
(at flywheel)Ft-lbs of torque@RPM 142ft-lbs @ 6800pm
Compression ratio eg. 11.4:1
Redline RPM: 8,500
(drivetrain info)
Gears: 4 Speed
Manual/Auto: Manual
Gear ratios (below)
1: 3.1
2: 2.31
3: 1.78
4: 1.44
5: (if applicable)
6: (if applicable)
Final drive ratio: 5.14
Driving wheels: Back
Car weight in kgs: 770kgs
front/rear weight distribution: 30/70
Wheelbase in cms: 390cm
Tire size: 245/95 R15 (33 inch BFG mud)
Coefficient of drag: .35 (god knows!, small frontal area, but not slippery by any stretch)
Overall height in cms: 250cm
Overall width in cms: 215cm
Ground clearance in cms: 45cm.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby RedMist » Tue Oct 25, 2005 2:57 pm
What is it with all these people that have overbored 4age's? Or don't they know how many cc a 4age is?
RedMist
Postby RomanV » Tue Oct 25, 2005 2:58 pm
Muahaha, it will be interesting to see how the bunderson will go. :twisted:
I am assuming that you have a 30 front, 70 rear weight bias?
You have it the other way around on your post.
Postby bad20v » Tue Oct 25, 2005 3:00 pm
RomanV wrote:Muahaha, it will be interesting to see how the bunderson will go. :twisted:
Maybe he's just really fat! 8O
Thank-You.
bad20v
Postby RedMist » Tue Oct 25, 2005 3:48 pm
bad20v wrote:Maybe he's just really fat! 8O
RevHead, can I borrow your Katana?
RedMist
Postby RedMist » Tue Oct 25, 2005 3:50 pm
Oh perhaps we should surmise that the Bunderson engine goes in my new purchase? A formula ford Van Dieman....
But no, its only going to be powered by a piddly little 180bhp 1300cc engine.
RedMist
Postby riddles » Tue Oct 25, 2005 5:02 pm
Car title/user name: ST205 3S-GTE, Riddles
(Engine info)
Displacement: 1998cc
Type: Turbo
(at flywheel)Horsepower@RPM 255hp@6000rpm
(at flywheel)Ft-lbs of torque@RPM 225ft-lbs @ 4000rpm
Compression ratio 8.5:1
Redline RPM: 7,400rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.384
2: 1.913
3: 1.258
4: 0.918
5: 0.731
6: n/a
Final drive ratio: 4.285
Driving wheels: 4wd
Car weight in kgs: 1380kgs.
Wheelbase in cms: 253.5cm
Tire size: 235/45 R17
Coefficient of drag: 0.35
Overall height in cms: 130.5cm
Overall width in cms: 175cm
Ground clearance in cms: 14.5cm
riddles
Postby RomanV » Tue Oct 25, 2005 7:43 pm
EDIT: Ive moved the big list to the first post, so you can just look there to see how things stack up when more cars are added.
Postby Brick » Tue Oct 25, 2005 7:57 pm
the litres per km average doesnt seem very accurate lol
correct me if im wrong buy say for all_fours, he goes through 13l of petrol per 1km?
Brick
I know Kung Fu
Postby RomanV » Tue Oct 25, 2005 8:12 pm
What? Cant you read or something?
My bad, fixed it
Postby madaltezza » Tue Oct 25, 2005 8:17 pm
[quote="nmemr2"]Car title/user name: NA toyota altezza
(Engine info)
Engine Location: frount
Type: NA
(at flywheel)Horsepower@RPM210@7600rpm
(at flywheel)Ft-lbs of torque@RPM216@6400
Compression ratio 11.5
Redline RPM: 8200rpm
(drivetrain info)
Gears: 6 Speed
Manual/Auto: manual
Gear ratios (below)
1: 3.874
2: 2.175
3: 1.484
4: 1.223
5: 1.000
6: .869
Final drive ratio:4.300
Driving wheels: Rear wheel drive
Car weight in kgs: 1,360kg
front/rear weight distribution: um, Wheelbase in cms: 267.
Tire size: front 215/45/r17 rear215/45/r17
Coefficient of drag: i have no idea,Overall height in cms: 141cm
Overall width in cms:172.5
Ground clearance in cms: 135cm?? that what my book says
skids are good
madaltezza
Postby Jebus » Tue Oct 25, 2005 8:18 pm
Thats pretty cool, cheers. :D However it seems my car needs more power....
Jebus
Postby durty starlet » Tue Oct 25, 2005 8:24 pm
RomanV wrote:Here is an example of what is required.
Car title/user name: eg. 4k starlet, durty starlet
(Engine info)
Displacement: eg. 1290cc
Engine Location: eg. Front
Type: eg. NA
(at flywheel)Horsepower@RPM eg. 58hp@5200rpm
(at flywheel)Ft-lbs of torque@RPM eg. 67ft-lbs @ 3600rpm
Compression ratio eg. 9:1
Redline RPM: eg. 6000rpm :roll:
(drivetrain info)
Gears: Eg. 4 speed
Manual/Auto: eg. manual
Gear ratios (below)
1: 3.789
2:2.220
3: 1.435
4:1
5:0.865
Final drive ratio:4.316
Driving wheels: eg. back
Car weight in kgs: eg. 782
front/rear weight distribution: eg. no idea
Wheelbase in cms: eg. 230cm.
Tire size: eg. 205/60 R13
Coefficient of drag: eg. no idea
Overall height in cms: eg. 135cm
Overall width in cms: eg. 153cm
Ground clearance in cms: eg. 19.5cm.
dont know about weight distribution or drag coefficient
all other stats straight out of haynes manual
durty starlet
Postby DJ » Tue Oct 25, 2005 8:52 pm
Sweet, I won everything 8) :lol:
DJ
Postby GGnz » Tue Oct 25, 2005 9:17 pm
I'd love to see some Toyota vs Honda comparisions. Like 20V vs B18c etc.
GGnz
Users browsing this forum: Bing [Bot] and 27 guests
