no_8wire wrote:What his aw11 with stuffed suspension?...that would have been safe....
bad20v wrote:Adamal wrote:bad20v wrote:Adamal wrote:Nuty|Mike's last run was a record breaker.
58 seconds @ 5.4kph
At least he had the balls to put his car down the strip
Good on ya Mike!!!
Sorry? What was that? I didn't hear you over the sound of your car not being able get into gear properly because of a "buggered bearing" in the clutch
For someone that had a big cry about his car getting a bit banged up awhile ago... and not even game enough to put his own car down to strip... you've got alot of nerve commenting on other peoples efforts and failures.
EVLTEK wrote:my best was 14.7@157...
track was pretty slippery - was more a case of not enough heat in the track cause the sun wasn't out and also there was too much rubber on the track and it was creating a lot of marbles out there on the launch pad.....
that would have been Chelles - stickers are $5eachZroaster wrote:EVLTEK wrote:my best was 14.7@157...
Spot on about the track, and specifically the marbles. I started the day off with a 15.03 , by the time of my semi in Class C I had run a 14.23 at 162.1 kph. I decided to go for the Doctor in the semi, hit boost/fuel cut (felt like an anchor was dropped) in low and second when I red lined.... and ended up running a 15.6 instead of the sub 14 I was aiming for. I'm still only able to "launch" at 1600rpm, and the Boost cut comes in approximately at 10 psi(still using T Piece to get me above the 7psi stock boost).
I'm going to hold off mods until early 2006, but am thinking of entering my sleeper in the Night drags........we will see closer to the day.
On another note, a lovely lady representing Toyspeed came up to me after the event and presented me with a TOYSPEED decal to put on my Cressida. I have MISPLACED it, so if that Lady can contact me, I wouldn't mind having another one... payment IS an option.
Al wrote:Chelles is a generous woman. Getting a free sticker out of me is like blood from a stone
Al wrote:One thing that I noticed was the timing....it seemed that it was just the quickest ET that won the race...not who got to the end first? Would I be correct to assume that.
