Toyspeed virtual drag race competition. *CLOSED FOR NOW*
- barryogen
- 2ZZ Guru in training
- Contact:
I have to admit, this is an f'ing cool program... and not too badly off for the 1/4 and 0-100(I had a go last night and got within 0.5 sec for both, which given I've never done it before isn't too bad).
dave.net.nz
Project "Better Altezza" - Dave Style
http://forums.toyspeed.org.nz/viewtopic.php?p=659132
Comments
http://forums.toyspeed.org.nz/viewtopic.php?p=659134
Comments
There you have it, the 3sgte aw11 is the ultimate car
Although I must say I doubt it would do a 12.3 1/4 mile, but if it did I'd be so happy I'd probably cream my pants.
in hindsight the engine HP figure I gave might have been a bit high, if drivetrain loss is 15% then I'd guestimate power should be more like 280hp
also the wild guestimate on the torque might be way off also
- XS1V
- Toyspeed Member
- Contact:
Car title/user name: AE101 GTZ / XS1V
(Engine info)
Displacement: 1587cc
Engine Location: Front
Type: SC
(at flywheel)Horsepower@RPM: 200hp@6100rpm
(at flywheel)Ft-lbs of torque@RPM: 175ft-lbs @ 4000rpm
Compression ratio 8.9:1
Redline RPM: 7200rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.392
4: 1.031
5: 0.815
Final drive ratio: 4.5
Driving wheels: front
(Chassis and body info)
Car weight in kgs: 1110kgs.
front/rear weight distribution: 60/40
Wheelbase in cms: 246cm.
Tire size: eg. 205/40 R17
Coefficient of drag: .29
Overall height in cms: 110cm
Overall width in cms: 170cm
Ground clearance in cms: 8cm.
(Engine info)
Type: SC
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.392
4: 1.031
5: 0.815
ST205 Group A Rallye #2363
- bad20v
- Toyspeed Member
- Contact:
RomanV wrote:XS1V wrote:Coefficient of drag: .29
U sure about that?
not many cars dip into the .2s
Not bad if its the factory C.D.
Dave, Brad's cars not actually black.... its Teflon coated!!!!
Thank-You.
Thank-You.
- barryogen
- Contact:
Just wondered if you could re-run mine with the following stats.
Basically I'm looking at the SC that Blitz do, and wondered what it would do to the stats.
Car title/user name:SC RunX barryogen/dave.net.nz
(Engine info)
Displacement: 1795cc
Type: SC
(at flywheel)Horsepower@RPM 276hp@7800rpm
(at flywheel)Ft-lbs of torque@RPM 219ft-lbs @ 6800rpm
Compression ratio eg. 11.5:1
Redline RPM: eg. 8,700rpm
(drivetrain info)
Gears: 6 speed
Manual/Auto: MT
Gear ratios
1: 3.17
2: 2.05
3: 1.48
4: 1.17
5: 0.92
6: 0.82
Final drive ratio:4.53
Driving wheels: Front
Car weight in kgs: 1230kgs.
front/rear weight distribution: 55/45
Wheelbase in cms: eg. 260cm.
Tire size: 205/50 R16
Coefficient of drag: .3XX
Overall height in cms: 141cm
Ground clearance in cms: 10cm.
Drag coefficient is a guestimate, the reast was gleamed from the sites provied, or google.
(Engine info)
Type: SC
(drivetrain info)
Gears: 6 speed
Manual/Auto: MT
Gear ratios
1: 3.17
2: 2.05
3: 1.48
4: 1.17
5: 0.92
6: 0.82
dave.net.nz
Comments
Comments
Here's what I've been able to find.
Car title/user name: AE86 Levin / JT
Bluetop 4age
Type: NA
(at flywheel)Horsepower@RPM 137hp@6600rpm
(at flywheel)Ft-lbs of torque@RPM 110ft-lbs @ 4500rpm
Compression ratio 9.4:1
Redline RPM: 7,700rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.587
2: 2.022
3: 1.384
4: 1.000
5: 0.861
Final drive ratio: 4.3:1
Driving wheels: back
Car weight in kgs: 990kgs
front/rear weight distribution: 56:44
Wheelbase in cms: 240cm
Tire size: 195/55 R15
Coefficient of drag: .35
Overall height in cms: 132.6cm
Overall width in cms: 162.6cm
Ground clearance in cms: 12cm
Car has been dyno'd and taken down the quater a couple of times so will be interesting to see how it compares.
Bluetop 4age
Type: NA
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.587
2: 2.022
3: 1.384
4: 1.000
5: 0.861
- Snoozin
- Toyspeed Member
- Contact:
As I would have thought the Alfa is fairly well represented in the handling type tests... I'd say power would let it down around the 'ring.
As for the quarter.... how do I get a 15.04 in real life... my best is a 16.1 @ 139km/h, so I think I best work on my technique
Top speed isn't too far off either... I've seen a radar verified smidgeon over 200km/h in my car....
Stealer Of Souls
- Toyspeed Member
Just on JT's stats there. (If it's a real 86 then use the t50 ratios)...
T50 Ratios are this
3.587
2.022
1.384
1.000
0.861
K50 are
3.789
2.220
1.435
1.000
0.865
T50 Ratios are this
3.587
2.022
1.384
1.000
0.861
K50 are
3.789
2.220
1.435
1.000
0.865
'86 AE85.5 Levin
boxxy wrote:GGnz wrote:I'd love to see some Toyota vs Honda comparisions. Like 20V vs B18c etc.
i wouldnt... i think those dirty dirty hoondas would pawn us (20v owners)all![]()
Speak for yourself
Car title/user name: AE82 Corolla GT / Lanius
(Engine info)
Engine Location:Front
Type: NA
(at flywheel)Horsepower@RPM 170@7800rpm
(at flywheel)Ft-lbs of torque@RPM 130@5600rpm
Compression ratio 11:1
Redline RPM: 8000rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.310
4: 0.969
5: 0.815
6:
Final drive ratio:
Car weight in kgs: 930kgs
Have copied the driveline ratios from someone elses post who appears to have a gearbox from either blacktop or silvertop 4AGE. Engine has been mildly modified, but I've left the power figures as standard.
I can't find anywhere accurate on the net that has the weight distribution, height, length etc for a NZ New AE82, so I've used the details from an AE86 as its roughly the same size / shape / weight as mine (although the 82s are supposed to be lighter than the 86s). If anyone is able to correct these details, PLEASE feel free
- XS1V
- Toyspeed Member
- Contact:
U sure about that?
Well thats all ive been able to find, or 0.30 was the other one so... what ever you want to use dave
just for a laugh
Car title/user name: SlowST202
(Engine info)
Displacement: 1998
Type: NA
(at flywheel)Horsepower@RPM 138@6000rpm
(at flywheel)Ft-lbs of torque@RPM 138@4400rpm
Compression ratio 9.5
Redline RPM: 6400
(drivetrain info)
Gears: 5 speed
Manual/Auto: Auto
Gear ratios (below)
1: 2.810
2: 1.549
3: 1.000
4: 0.706
5:
6: (if applicable)
Final drive ratio: 3.95:1
Car weight in kgs: 1190 (dry weight)
front/rear weight distribution: ?
Wheelbase in cms: 253.5
Tire size: 205/55 R15
Coefficient of drag: ?
Overall height in cms: 130.5
Overall width in cms: 145.0
Ground clearance in cms: 14.5
(Engine info)
Displacement: 1998
Type: NA
Redline RPM: 6400
(drivetrain info)
Gears: 5 speed
Manual/Auto: Auto
Gear ratios (below)
1: 2.810
2: 1.549
3: 1.000
4: 0.706
5:
6: (if applicable)
Hey, whats the program called? I might try get a hold of it? If not could you email it to me on ggriffiths@tekotago.ac.nz
SnoozinEuro wrote:As for the quarter.... how do I get a 15.04 in real life... my best is a 16.1 @ 139km/h, so I think I best work on my technique![]()
Have you weighed your car or had it on the dyno? With your power to weight ratio as listed you should have a higher trap speed than that which could indicate one or both of those two is a little off.
- barryogen
- Contact:
JT wrote:SnoozinEuro wrote:As for the quarter.... how do I get a 15.04 in real life... my best is a 16.1 @ 139km/h, so I think I best work on my technique![]()
I would imagine that we are listing the car weight, and not adding the driver to it... me, I'd kill my cars performance, I add 134Kgs to my car... not to mention if it had a full tank of gas(another ~50kgs)
dave.net.nz
Comments
Comments
I'll add the extra cars in tonight if I have the time.
Anyone who wants this program, can get it here:
http://www.cartestsoftware.com/cartest4.5/
