Toyspeed virtual drag race competition. *CLOSED FOR NOW*
Postby Lanius » Fri Oct 28, 2005 10:40 am
RomanV wrote:I'll add the extra cars in tonight if I have the time.
Anyone who wants this program, can get it here:
http://www.cartestsoftware.com/cartest4.5/
I'm just keen to see where mine will appear in the times and 1/4 mile list compared to the AE111s :)
Lanius
Postby RomanV » Fri Oct 28, 2005 10:49 am
No worries, will let you know.
Postby Snoozin » Fri Oct 28, 2005 12:33 pm
JT wrote:
SnoozinEuro wrote:As for the quarter.... how do I get a 15.04 in real life... my best is a 16.1 @ 139km/h, so I think I best work on my technique :lol:
Top speed isn't too far off either... I've seen a radar verified smidgeon over 200km/h in my car....
Have you weighed your car or had it on the dyno? With your power to weight ratio as listed you should have a higher trap speed than that which could indicate one or both of those two is a little off.
Weighed in at 860kg on the weighbridge.... power is factory output plus a conservative 5hp allowing for extractors, exhaust, and minor head work.
:S
Snoozin
Postby Bazda » Sun Oct 30, 2005 11:40 am
Car title/user name: 7AGTE 20v Levin/ Bazda
(Engine info)
Displacement: 1764cc
Engine: Turbo
Horsepower@RPM: 400hp@7600rpm
Ft-lbs of torque@RPM: 400ft-lbs @ 6300rpm
Compression ratio: 8.0:1
Redline RPM: 8000rpm
(drivetrain info)
Gears: 5 Speed
Manual/Auto: Manual
Gear ratios (below)
1st - 3.214
2nd - 2.045
3rd - 1.333
4th - 0.972
5th - 0.820
Final drive ratio: 3.944
Driving wheels: Front
(Chassis and body info)
Car weight in kgs: 1070kgs
front/rear weight distribution: 60/40
Wheelbase in cms: 243cm
Tire size: 205/17/45
Coefficient of drag: .35
Overall height in cms: 130cm
Overall width in cms: 168cm
Ground clearance in cms: 10cm
Postby aesc » Sun Oct 30, 2005 1:26 pm
Car title/user name: AE101 Levin GTZ / aesc
(Engine info)
Displacement: 1587cc
Engine Location: Front
Type: Supercharge
(at flywheel)Horsepower@RPM: 180hp@5500rpm
(at flywheel)Ft-lbs of torque@RPM: 190ft-lbs @ 4400rpm
Compression ratio 8.9:1
Redline RPM: 7000rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.214
2: 2.045
3: 1.333
4: 0.972
5: 0.820
Driving wheels: front
Car weight in kgs: 1150kgs.
Wheelbase in cms: 246cm.
Tire size: eg. 215/40 R17
Coefficient of drag: 0.35
Overall width in cms: 170cm
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Bazda » Sun Oct 30, 2005 1:34 pm
aesc wrote:Car title/user name: AE101 Levin GTZ
(Engine info)
Type: Supercharge
(at flywheel)Ft-lbs of torque@RPM: 190ft-lbs @ 4000rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.392
4: 1.031
5: 0.815
Final drive ratio: 4.5
Overall height in cms: 110cm
why are your gear ratios different to mine???? I have the ae101 gtz box... Have i used the wrong gear ratios...
oh you have used the 20v gear box specs they arent the same as the GTZ box :)
Postby aesc » Sun Oct 30, 2005 3:26 pm
Bazda wrote:why are your gear ratios different to mine???? I have the ae101 gtz box... Have i used the wrong gear ratios...
Woops :oops: I took my gear ratios off XSIV for some reason, but have fixed them to the same as yours now Bazda :)
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Virtual Genocide » Sun Oct 30, 2005 3:30 pm
KP62, Virtual Genocide
(Engine info)
Displacement: eg. 1298cc
Engine Location: front
Type: NA
(at flywheel)Horsepower@RPM 90@6500rpm
(at flywheel)Ft-lbs of torque@RPM 75ft-lbs @ 3500rpm
Compression ratio 9.4:1
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.789
2: 2.220
3: 1.435
4: 1
5: 0.865
Final drive ratio:3.9
[color=green]Driving wheels:
rear
Car weight in kgs: 700kgs.
Wheelbase in cms: 2300cm.
Tire size: 195/50 R15
Overall height in cms: 1380cm
Overall width in cms: 1535cm
Ground clearance in cms: 11cm.
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby snwtoy » Sun Oct 30, 2005 5:21 pm
Car title/user name: Caldina GT-T ST215, snwtoy
(Engine info)
Displacement: 1998cc
Type: Turbo
(at flywheel)Horsepower@RPM 260 @ 6000 rpm
(at flywheel)Ft-lbs of torque@RPM eg. 238 @ 4400rpm
Compression ratio 9:1
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.38
2: 1.913
3: 1.333
4: 0.972
5: 0.731
Final drive ratio:
Driving wheels: 4wd.
Car weight in kgs: 1440kgs.
front/rear weight distribution: ?
Wheelbase in cms: 258cm.
Tire size: 225/35/18
Coefficient of drag: ?
Overall height in cms: 145 cm
Overall width in cms: eg. 172 cm
snwtoy
Postby Bazda » Fri Nov 04, 2005 8:43 am
i wana see my times :o
Postby Lanius » Fri Nov 04, 2005 9:59 am
ditto ... tried downloading the program, but it won't work with the "unique" java the environment requires here :roll:
tried using the online one, but that doesn't load :?
Lanius
Postby RomanV » Fri Nov 04, 2005 10:23 am
Erm... Sorry guys.
Been rather busy the last week or two.
Will try to update it soon.
Postby Lanius » Fri Nov 04, 2005 10:36 am
No worries man, not trying to be pushy ... just wanna see how it evaluates my car :P
You have PM btw ;)
Lanius
Postby aesc » Fri Nov 04, 2005 10:52 am
Bazda wrote:i wana see my times :o
Ditto that 8)
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Flange » Sat Nov 05, 2005 9:05 am
Car title/user name: AE85.6, Rob
(Engine info)
Type: NA
(at flywheel)Horsepower@RPM eg. 130hp@6600rpm
(at flywheel)Ft-lbs of torque@RPM eg. 97@4800
Compression ratio eg. 9.4:1
Redline RPM: eg. 7,600rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: Manual
Gear ratios (below)
1: 3.587
2: 2.022
3: 1.384
4: 1
5: 0.861
Final drive ratio:
Driving wheels: Rear
Car weight in kgs: eg. 910kgs
Wheelbase in cms: ?
Tire size: eg. 205/60R13
Overall height in cms: ?
Overall width in cms: ?
Ground clearance in cms: 13
Flange
Postby Difficult_E » Sat Nov 05, 2005 10:34 pm
Car title/user name: 86 FXGT Corolla / Reilly
(Engine info)
Displacement: 1598 cc
Type: NA
(at flywheel)Horsepower@RPM 128@6600rpm
(at flywheel)Ft-lbs of torque@RPM ??
Compression ratio
Redline RPM: eg. 8,000
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Car weight in kgs: ?
Wheelbase in cms: ?
Tire size: eg. ?
Ground clearance in cms: ?
Difficult_E
Postby Alex B » Sat Nov 05, 2005 11:01 pm
Car title/user name: pyro_sniper2002 AE95
(Engine info)
Type:NA
(at flywheel)Horsepower@RPM 90bhp@6000rpm
(at flywheel)Ft-lbs of torque@RPM. 95ft-lbs @ 3600rpm
Compression ratio 9.5:1
Redline RPM:. 6,200
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.538
2: 2.045
3: 1.333
4: 0.972
5: 0.820
6:
Final drive ratio:
Car weight in kgs: 1080kg
front/rear weight distribution: 65/35?
Wheelbase in cms: 243cm.
Tire size: 185/70 R13
Overall height in cms: 138cm
Overall width in cms: 422.5cm
Ground clearance in cms. 17cm.
Oh and its super white 2 :P
Postby RomanV » Sun Nov 06, 2005 12:50 pm
Will try to get the new cars done tonight after work.
Postby Truenotch » Sun Nov 06, 2005 3:08 pm
Car title/user name: N/A Aw11 Truenotch
(Engine info)
Engine Location: mid
Type: na
(at flywheel)Horsepower@RPM 140@7200rpm
(at flywheel)Ft-lbs of torque@RPM 107ft-lbs @ 6000rpm
Compression ratio 10.3:1
Redline RPM: 7,750 rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.310
4: 0.969
5: 0.815
Final drive ratio: 4.312
Driving wheels: back
Car weight in kgs: 980kg
front/rear weight distribution: 44.5 / 55.5
Wheelbase in cms: 232cm
Tire size: 195/50 15
Coefficient of drag: 0.34
Overall height in cms: 123.5cm
Overall width in cms: 166.5cm
Ground clearance in cms: 12.7cm
Truenotch
Postby deaf_rattle » Sun Nov 06, 2005 4:24 pm
MA61 Deaf_rattle
(Engine info)
Displacement: eg. 2954
Type: turbo
(at flywheel)Horsepower@RPM eg. 400hp@7200rpm
(at flywheel)Ft-lbs of torque@RPM eg. 400ft-lbs @ 3200rpm (guessimation)
Compression ratio eg. 8.4:1
Redline RPM: 7600rpm
(drivetrain info)
Gears: 4
Manual/Auto: Auto
Gear ratios (below)
1: 2.804
2: 1.531
3: 1
4: 0.705
5:
6:
Final drive ratio: 3.909
Car weight in kgs: 1200kgs.
front/rear weight distribution: eg. 54/46
Wheelbase in cms: 263.
Tire size: 215/60/R15
Overall height in cms: 132
Overall width in cms: 172
Ground clearance in cms: 10cm.
Users browsing this forum: No registered users and 26 guests
