Akane wrote: intake Air-Temp stayed around 38-ish degrees for those who are interested in side mount GReddy intercooler for the MR2.
Akane wrote:None of that water injection crap, just a GReddy intercooler kit for the MR2, and a stock i/c fan running 24/7.
My friend was out in twilight roads doing some "testing" with the car, it stayed at the same temp too.
If I'm crusing in this weather, it says at 29 degrees, a couple months back cruising would be around 20-25 degrees. Once I stop in traffic the engine will heat up the sensor upto 35 degrees(air will stay in the intake pipe as while idle you get air from the bypass pipe anyway, so it heats up etc.....)
Boost is 1 bar.
Akane wrote: it's colder than Wildcard's bed.
Akane wrote:So yeah. The only problem I see is the pipe before the thottle body, it's always warm due to engine heat.
Akane wrote:Okay, I was there that day with my MR2 (ASSBEE organised pukekohe day / Nizan).
firstly, there's a Civic Type R who got owned.
then a SK2 got owned too.
There's a black AE111 which is ungodly quick it was running circles around all the street cars there is, yes it's NA, slick tires, stripped interior, it's the same kind of those crazy fast circuit cars you see in Japan.
There was the ST hi-tec modified black Silvia S15 Spec-R II (Featured in NZPC mag), which is crazy fast, it was dominating everything down the straight.
A lot of EVO 8's, STi's etc showed up.
An Accord Euro owned me around the bends but it was running semi-slicks. And anyone seen my dodgey NS-1's in the front will understand why.
I managed to pull 2 decent drifts around the hairpin while I spun out about 4 times, couldn't do the S bends, need better tires up front I was understeering into things.
My car overheated after 2 laps, due to dodgey tuner blowing up my head gasket.
Also melted my airtemp sensor wire together, I spent most of the time in the pits sorting out my car.
up the right hander where the CTR and the S2K got owned, I didn't go WOT, *TOO* scared especially with the Positive camber on my rear/left tire. Down that front straight I max out about 190kph, that's without going all out on that right hander
there was a Viper Race car which is ungodly quick, a Mustang of some sort I guess which is crazy loud, and there's a Holden appearntly with 800hp passed me at high speed like I pass Honduhs but spewing blue smoke.
Akane wrote: But yea, if your WI works for you then congratsSteam cleaning should be reserved to Versace suits.
the fallen303 wrote:does anyone know where to find a list of upcoming track open days? i think they're usually done during the week, and about $80 or so? tried looking on google, but couldn't find anything.
