any tricks to removing a crank pulley?
Postby rollas22 » Fri Nov 04, 2005 9:49 am
need to remove the crank pully on my bmw 320i to set the timing chain
Seems dam impossible to crack the bolt, just wont budg!!!
Is there any tricks?
Ive tried puting the car in 2nd gear, still wont work. Do i need to use a rattle gun???
HELP!!!
KE-Corolla's for life!!!
rollas22
Postby Silent Knight » Fri Nov 04, 2005 9:54 am
Lots and Lots of CRC and also if you can remove the radiator etc in front of it you could put the powerbar on an angle and stand on it.
This is what I would do. Normally when I can't crack a bolt I use lots of CRC and find someway to get at it with my foot. This technique has never failed me. :wink:
Silent Knight
Postby AJz » Fri Nov 04, 2005 10:22 am
Silent Knight wrote:Normally when I can't crack a bolt I use lots of CRC and find someway to get at it with my foot. This technique has never failed me. :wink:
Hahahhahaha, nice
I had vtax :(
AJz
Postby rollas22 » Fri Nov 04, 2005 10:40 am
Yep ive removed the radiator, and have tried using the powerbar with the extension and the socket! but no success. Must have some extreme locktite on it or something. Think the rattle gun is the only option that will work.
rollas22
Postby aesc » Fri Nov 04, 2005 10:50 am
Have you tried jamming the power bar somewhere on the chassis and flicking the starter?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby rollas22 » Fri Nov 04, 2005 12:29 pm
aesc wrote:Have you tried jamming the power bar somewhere on the chassis and flicking the starter?
Nope but ill give that a try tonite. Fingers crossed that it will work :?
rollas22
Postby Caveman » Fri Nov 04, 2005 12:31 pm
Powa bar is far superiour to an impact wrench.
Just use the biggest socket set you have (you'd want bigger than half inch atleast) and the biggest f*ckoff bar you can find. Heaps of CRC as Silent Knight says.
Caveman
Postby rollas22 » Fri Nov 04, 2005 12:33 pm
1998 wrote:Powa bar is far superiour to a impact wrench.
Yep used the perfect sized socket, with a large f#*K off power bar, heaps of CRC and still wont budge at all!!! Gunna give the crank over wit starter motor a blast tonite.
rollas22
Postby Caveman » Fri Nov 04, 2005 12:36 pm
Wow then I doubt you'll get it off with a impact wrench. Worth a try though, but youll need a pretty decent sized one to top the mightly power bar. Good luck with it.
Caveman
Postby TrouserFxGt » Fri Nov 04, 2005 12:39 pm
ccw thread?
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby rollas22 » Fri Nov 04, 2005 12:40 pm
TrouserFxGt wrote:ccw thread?
WOuldnt have a clue bud. How do u tell???
rollas22
Postby bad20v » Fri Nov 04, 2005 12:46 pm
Undo the crank pulley and check the thread. 8)
Thank-You.
bad20v
Postby rollas22 » Fri Nov 04, 2005 12:56 pm
Hahaha yep will do when i get that dam pulley off!!!
rollas22
Postby RomanV » Fri Nov 04, 2005 1:02 pm
rollas22 wrote:Yep ive removed the radiator, and have tried using the powerbar with the extension and the socket! but no success. Must have some extreme locktite on it or something. Think the rattle gun is the only option that will work.
Are sure you're turning it the correct way? :lol:
Postby rollas22 » Fri Nov 04, 2005 1:05 pm
Haha yes im pritty sure im turning it the correct way...
rollas22
Postby SIDE_FX » Fri Nov 04, 2005 2:42 pm
put your wrench watever on the bolt and tap it wit a metal headed hammer sounds daft but after this old guy watched me trying to do the same to my 4age crank came a did it took him 4 hits 8O i felt so stupid
SIDE_FX
Postby rollas22 » Fri Nov 04, 2005 2:50 pm
SIDE_FX wrote:put your wrench watever on the bolt and tap it wit a metal headed hammer sounds daft but after this old guy watched me trying to do the same to my 4age crank came a did it took him 4 hits 8O i felt so stupid
Sweet give that a go tonite as well!!!
rollas22
Postby deaf_rattle » Fri Nov 04, 2005 5:31 pm
take out a spark plug, rotate motor so that piston is at its bottom most posistion.
with a nice soft nylon type rope, stuff that into the bore.
rotate the motor till the rope is jammed.
then try and crack it.
amatures :lol:
Postby Skidman » Fri Nov 04, 2005 10:29 pm
Get a gas torch and heat the bolt till its a bit red...dont go overbord tho, be careful of whats BEHIND it too.
Then hit it with the rattle gun while its still red hot. (common method back in the day)
Dosnt work every time either, but then again nothing dose..dose it?
Hondas are made for people who dont know better.
Skidman
Postby deaf_rattle » Sat Nov 05, 2005 7:54 am
Skidman wrote: but then again nothing dose..dose it?
the rope in the bore method works very well.
done it several times on the 5mges and 7mgtes ive had to remove the crank pulley from.
good trick i learnt from David (toymad)
