Who is going to be the first caldina into the 12s
Postby Santa'sBoostinSleigh » Wed Nov 02, 2005 10:55 pm
Bazda wrote:30kg!! hmm i havent had a car with 30kg rear seats before, what they made of? cast iron?
considering they fold down and have a steel backing on them i would have to agree there would be a huge saving!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby TWSTD » Thu Nov 03, 2005 7:10 am
Yes the rear seats in the caldina do weight a substantial ammt.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby 99gtt » Fri Nov 04, 2005 2:05 pm
My car wont be ready for nightspeed tonight but definatly will be ready for the next one. Twstd are you racing tonight.
SOON TO BE 500 HP
99gtt
Postby TWSTD » Fri Nov 04, 2005 2:38 pm
Sure am :-)
Click here!
TWSTD
Postby bad20v » Fri Nov 04, 2005 2:57 pm
TWSTD wrote:Sure am :-)
*looks at the clouds outside*
You reakon? :?
Thank-You.
bad20v
Postby Bazda » Fri Nov 04, 2005 11:28 pm
no 12s for twisted this time...but there were some fast cars tonight!!
Postby TWSTD » Sat Nov 05, 2005 10:53 am
nope - than damn 13.2 again and knocked out in the first round by a 12sec flat mitsi :-(
Click here!
TWSTD
Postby Al » Sat Nov 05, 2005 11:31 am
How do you launch the car? Tried a rev limiter launch? Its brutal but you have the trap speed for 12s; the only thing I can see holding you up is a slow 60ft or slow shifting.
Al
Postby IH8TEC » Sat Nov 05, 2005 11:58 am
Al wrote:How do you launch the car? Tried a rev limiter launch?
you rapist :lol:
Postby snwtoy » Sat Nov 05, 2005 12:29 pm
Anyone know the owners of the black gt-t 's which were racing last night? One was only pulling 15s...
snwtoy
Postby Malcolm » Sat Nov 05, 2005 12:47 pm
Al (Twstd), what 60fts are you pulling for your 13.2s? And how are you launching? And what trap speeds? I know how it feels getting knocked out of the first round, first time I raced I was knocked out in the first round by Joe Kyle's skyline, and next time in the first round by an 11 second legacy :evil: (they came first and second in that class that year)
Postby TWSTD » Sat Nov 05, 2005 1:43 pm
Basically i give it about 4000-4500 rpm and dump the clutch. Heres some stats:
1st round run:
RT: 0.380
60': 1.860
1/8: 8.527 @ 132.24 kph
1/4: 13.278 @ 168.06
On a warm up run I got:
RT: 0.470
60': 2.043
1/8: 8.733 @ 133.74 kph
1/4: 13.484 @ 167.51
comments welcome :-)
Click here!
TWSTD
Postby Al » Sat Nov 05, 2005 1:59 pm
You gotta cut your 1/8ths down. Even with a 2.0 60ft I can reel out a 8.2 second 1/8th.
Al
Postby TWSTD » Sat Nov 05, 2005 2:08 pm
how might i do that? shifting too soon into 2nd maybe?
Click here!
TWSTD
Postby Malcolm » Sat Nov 05, 2005 2:22 pm
you need to compare apples with apples - an mr2 is quite a bit different and difficult to compare to a heavier 4wd
anyway, to me one big thing that needs work looks like the 60 foots. You really need to cut them down into the 1.7's. For what it's worth I used to launch at higher revs than that (probably around 5,500), with a little wheel spin (nothing excessive) and my best 60ft was 1.74
do you feel like you get a lot of wheelspin off the line? how about on 2nd gear change? might also need to speed up your shifts
I think you're going to have to really get everything right to get into 12's with 168 traps.
Postby fivebob » Sat Nov 05, 2005 3:41 pm
Are you using the Launch RPM ignition cut feature of the EManage to build boost on the line, or the Ign cut feature to allow power shifting?
Postby TWSTD » Sat Nov 05, 2005 6:05 pm
no im not... would be nice if the greddy manual was in gramatically correct english, let alone complete with technical information!
Click here!
TWSTD
Postby fivebob » Sat Nov 05, 2005 6:21 pm
TWSTD wrote:no im not... would be nice if the greddy manual was in gramatically correct english, let alone complete with technical information!
I thought this page was reasonably self explanatory.
Set the first box to lauch RPM, second on to max RPM, and third one to power shift max RPM, plus add a switch for power shift detection (on the clutch?).
Then set the throttle position above which Ignition cut will occur, add an ignition timing adjustment (retard the ignition to build boost and for a mild anti-lag effect), and select the number of pulses before launch control deactivates.
Postby FrEsH » Sat Nov 05, 2005 6:29 pm
sounds complicated 8O
FrEsH
Postby TWSTD » Sat Nov 05, 2005 6:39 pm
Thanks - I will look into this - the issue is i know nothing about what settings would be appropriate etc as ive never used a launch control of any sort before.
Click here!
TWSTD
