20v Timing
20v Timing
Postby phat_levin » Sat Nov 05, 2005 3:24 pm
did a search and have been browsing for about an hour now but didnt find much on what advancing the timing on my 20v would do for its performance? it is going to run a bit better with it advanced? how far can you safely advance it? thanks!
phat_levin
Postby Mr Revhead » Sat Nov 05, 2005 4:22 pm
wot fuel do you run? on 96 they actually go better dropped back to 8 degrees.
factory is 10deg
dont forget to bridge the terminals
Postby Lanius » Mon Nov 07, 2005 1:00 pm
Mr Revhead wrote:wot fuel do you run? on 96 they actually go better dropped back to 8 degrees.
factory is 10deg
... and on 98? Leave at 10?
Lanius
Postby Mr Revhead » Mon Nov 07, 2005 1:02 pm
i think so. havnt had the chance to ty it.
but thats whatll ill be doing when we get 98 here
Postby Armourermike » Mon Nov 07, 2005 2:09 pm
Toyota tuned my black top to 15 degrees. Asked a engine tuner to check out the timing, fuel air mixture and dyno it a few weeks later.
He said its all running pefectly so didnt want to change it. Felt like it had slightly more power before the Toyota mechanics tuned it.
Armourermike
Postby Mr Revhead » Mon Nov 07, 2005 2:12 pm
15?! itll be pinking like a gay man 8O
hell my 101 pinks at 10
Postby AceSniper » Mon Nov 07, 2005 4:03 pm
some engines may tolerate more than others with carbon buildup an all, I ran my silvertop an blacktop on 10 using gull 96 and havent had a problem if you look at the front edges on the dizzy and the top edge of the head you can line them up and thats 10deg no timming light needed :D
AceSniper
Postby RedMist » Mon Nov 07, 2005 4:39 pm
I think you'll find that at 15 degrees the ECU wound back the knock correction map so that its operating just before (or on) detonation. Max engine power is a few degrees before detonation so RevHeads suggestion should yield better results.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
