vvega wrote:hha check the points again
if they have pitting replace the condensor on the side of the dizzy
v
overcast wrote:Plugs for a 4k should be BP5ES (ngk or equivilent)
Jebus wrote:Electronic ignition would make all these troubles go away
Vertigo wrote:btw, it will get REALLY bad if you ignore it. eventually it would jutter and stall in unfortunate places. and then not start.
Virtual Genocide wrote:Jebus wrote:Electronic ignition would make all these troubles go away
Not another one.
Waste of time if you want reliability IMO
Electronic ignition on the 4k (etc) has a tendency to blow the ignitor. Not to mention the advance curve *shudder*
Virtual Genocide wrote:overcast wrote:Plugs for a 4k should be BP5ES (ngk or equivilent)
Are you sure?
If the engine's standard he should be using the larger electrode verisons. Which is what toyota specify. The BP5EA-L or the BRE527Y IIRC
In saying that i use the BPR5EY in my 4k, but it has higher compersion etc etc![]()
overcast wrote:Check the leads, dist cap, condensor, plugs, also mite be worth replacing the fuel filter and clean the carb.
Users browsing this forum: Google [Bot] and 25 guests
