new cams!
new cams!
Postby bzr ae111 » Tue Nov 15, 2005 8:51 pm
i recently went a priced up some "fast street" cams and valve springs from kelford cams in chch,the cams r $937 and the valve springs are $400....its quite expensive and im wondering if the amount of power gain i will get from these parts will be worth the money? any help would be much appreciated :D and do u think the power gains will be dramatic or not so dramatic?
bzr ae111
Postby Alex B » Tue Nov 15, 2005 8:52 pm
Its a good way to loose all your power round town any way :lol:
Postby bzr ae111 » Tue Nov 15, 2005 8:55 pm
how do you mean?
bzr ae111
Postby fx gt » Tue Nov 15, 2005 8:56 pm
they only start working effectially around 4 grand,am i correct?
fx gt
Postby bzr ae111 » Tue Nov 15, 2005 8:57 pm
well 3500 rpm but wen it hits that rpm is the power increase like noticeable?
bzr ae111
Postby Jebus » Tue Nov 15, 2005 8:58 pm
They should give her a fair bit more honk, will be cool to drive. Youll probaly find it idles like a c**t, but if ya get adjustable cam gears ya should be able to get it to behave like normal. $400 for springs is kinda steep, what kind are they?
But kelford will run ya through all this.
Jebus
Postby bzr ae111 » Tue Nov 15, 2005 9:02 pm
yeh i thought it might,ummm not entirely sure bout the make i just priced it up from kelford cams cos i know there pretty well known
bzr ae111
Postby Jebus » Tue Nov 15, 2005 9:08 pm
Franklins springs are half that, might save ya a couple of hundy.
Bout $230 from Franklin.
But should be cool with the cams, id look at adjustable cam gears though.
Jebus
Postby bzr ae111 » Tue Nov 15, 2005 9:14 pm
sweet az,cheers for your help dude :D
bzr ae111
Postby Jebus » Tue Nov 15, 2005 9:24 pm
Nope, but youll get descent gains out of an aftermarket ECU.
Jebus
Postby CozmoNz » Tue Nov 15, 2005 9:41 pm
heh... your replying to my post which i removed.
Origional post: "Ecu wont like it will it?"
In which i removed it, because we dont know the duration, the lift, or anything about the cams in question, and i couldnt be buggered looking up the kelford site... so i just removed my post.
But now its just weird you replying to nothing :D
Rayne For President!
CozmoNz
Postby Jebus » Tue Nov 15, 2005 9:51 pm
Then youre an ass. Kelfords fast street cams are about 260 intake and 252 exhaust, and are fine with stock ECU.
Jebus
Postby vhpacer » Tue Nov 15, 2005 10:12 pm
Couldnt you just get your standard cam/s reground if you want to save a bit of dosh??? :?:
vhpacer
Postby Jebus » Tue Nov 15, 2005 10:17 pm
Billets are better, and with regrinds you either need to add more meat to them to give them lift (then shim changes) or grind them with standard lift and extend the valves (bout 70 thou).
Jebus
Postby Caveman » Tue Nov 15, 2005 11:49 pm
It'll be fun as to drive, I recon you should do it. But then again I consider my car a toy so practicality is thrown out the window 8)
Caveman
Postby FYADUP » Wed Nov 16, 2005 12:37 am
but overall, to get sum descent power out of a 1600, epsecially to beat the vtecs like at honda toyspeed drags, which as many people sed we need faster NA's, you'll have to spend alot for NA for good power increase, thats the bugger with NA....
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
ecu
Postby bzr ae111 » Wed Nov 16, 2005 8:45 am
i was considering gettin an aftermarket ecu for my car but man there hard to come by for a 1600 na,does ne1 know where i could get one? or otherwise i was thinkin bout gettin a apexi safc as they r cheaper,do u think that would be suffient?
bzr ae111
Re: ecu
Postby Santa'sBoostinSleigh » Wed Nov 16, 2005 9:14 am
bzr ae111 wrote:i was considering gettin an aftermarket ecu for my car but man there hard to come by for a 1600 na,does ne1 know where i could get one? or otherwise i was thinkin bout gettin a apexi safc as they r cheaper,do u think that would be suffient?
plenty of link and link plus's around....
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Re: ecu
Postby Lanius » Wed Nov 16, 2005 10:39 am
It sounds as though you think you need a specific ECU for your car ... ? Not quite correct - any aftermarket ECU will work, some just offer more features (which you probably don't need; eg boost control). As someone else said, Link or Link Plus will be plenty :)
Just remember if you're getting performance cams installed to replace the factory ones, your torque and power curves are going to change. Power will come on later, and will be more concentrated at the top end, and you're going to lose power in the lower and mid rev range. The car will feel and sound great pulling onto the motor, or screaming round a track, but its not going to be as good for day-to-day round town driving, simply because there isn't that much room to hit the revs you're looking at that often (in anything other than 1st and 2nd gear).
Lanius
Re: ecu
Postby B1NZ » Wed Nov 16, 2005 6:19 pm
With an Apexi SAFC2 you will be getting a gain of about 7kw@wheels for your $1200-$1500 approx
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Users browsing this forum: Google [Bot] and 1 guest
