Corolla 1976 ke30
Corolla 1976 ke30
Postby Difficult_E » Tue Nov 08, 2005 9:10 pm
What kinda engine would i be able to drop into this? its just got the 4k in it atm.
Thanks in advance.
1986 FXGT Corolla
Difficult_E
Postby z|gen » Tue Nov 08, 2005 9:14 pm
use the search function.
AE91 SUPERCHARGED COROLLA
z|gen
Postby Lloyd » Tue Nov 08, 2005 9:16 pm
Can put anything in it you want. If you're asking then chances are you're paying someone to do the work so might be best to work the 4K a little bit.
What are you wanting out of it? Could put anything in it such as 4AGE, 5K, SR20, 2JZGTE, 3UZFE, 13BT, RB20DET etc etc etc
All comes down to how much money/time/effort you want to throw at it.
Postby Jebus » Tue Nov 08, 2005 10:05 pm
Difficult_E wrote:What kinda engine would i be able to drop into this? its just got the 4k in it atm.
Thanks in advance.
You could drop any K series into it, otherwise a 4AGE or 2/3T with specific mounts will also drop in. Not much else will. And by drop I mean physically sit in the engine bay and bolt to your crossmember, making it go is a different story.
If you want more info on converting these motors (been covered 2114124 times) then do a search of google or toyspeed.
Jebus
Postby vhpacer » Tue Nov 08, 2005 10:22 pm
My old man had an sr coupe back in the day with a 308 holden v8 in it!! Yeh so anything can be done just depends how much work you want to do/$$ you have...
vhpacer
Postby Difficult_E » Sun Nov 20, 2005 3:01 pm
If i got a 4age would it need modifying to run in the ke30?
1986 FXGT Corolla
Difficult_E
Postby vhpacer » Sun Nov 20, 2005 3:24 pm
Yeh a bit, go to club-k, theres heaps on there about this conversion, also on here. Theres alot more to a conversion than people sometimes think. Theres heaps of small things and youve got to change or mod heaps of stuff, like diffs,radiators, brakes,suspension usually, fuel system etc.
vhpacer
Postby ke_25 » Sun Nov 20, 2005 10:55 pm
diffs and stuff can handle it ok, it just depends how you drive it, i think the standard brakes can pass cert if you just running a n/a 4age aswell, aslong as they have some good pads on them.
3SGTE out of a celica gt4 or somethign would go quiet well...
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby monkey_boy » Sun Nov 20, 2005 11:50 pm
[quote="ke_25"]diffs and stuff can handle it ok...quote]
We've blown up many a KE30 diff and broken a few axles due to stress from skids or dragging.
The main problem was its a worked 4k with high lift cam(s?) lightened flywheel and clutch etc... and the standy diff couldnt handle it, a Hilux 8" does nicely, altho blew it up last saturday... the axles on this particular '30 dont like the wheels that are on it - some brand of 16"x205x45. They just drag the axle and snap it on corners.
If you're upgrading the engine and plan to drive the car hard, either in a straight line or around corners then you may like to think about upgrading the Diff and axles.
Just my 2c tho.
Peace
One day monkey's will rule the world, then it will be bananas on toast for breakfast... Every day....
monkey_boy
Postby ke_25 » Mon Nov 21, 2005 12:02 pm
ke_25 wrote:it just depends how you drive it
ke_25
