Mr Revhead wrote:yes
beeker wrote:Mr Revhead wrote:yes
immmm,
My AE101/4agze powered AE86 dont have one (after market extractors).
Recommend to fit one ?
Note: Its Targa / competition use only. S/C is also Hard wired on full time.
True-No-Turbo wrote:beeker wrote:Mr Revhead wrote:yes
immmm,
Are you running the standard ECU? I thought the ECU would go into failsafe with no signal from the O2 sensor?
I would say you should fit one as the ECU needs a signal back to judge inj/ pulsewidth and would stay in Open Loop mode or go into failsafe "engine check"....wouldnt it ???
Tap the O2 into the collector.
However saying that Ive also seen aftermarket extractors on a Nissan SR20 where the O2 sensor was at the first 2/1 collector NOT the end collector, dunno if the extractor factory didnt think about this to well or what?? Maybe it dont matter??
TNT
True-No-Turbo wrote:Things you find on trade me - Here ya go![]()
http://www.trademe.co.nz/Trade-Me-Motor ... 794031.htm
beeker wrote:True-No-Turbo wrote:Things you find on trade me - Here ya go![]()
yeah saw that, and was gonna have a go, just as long as its the correct part. Assume these are all the same ?
True-No-Turbo wrote:beeker wrote:True-No-Turbo wrote:Things you find on trade me - Here ya go![]()
Thats the puppy - Its out of an AE101 GTZ, Have you got the plug off the loom to tap it in??
no_8wire wrote:Maybe because it was a dedicated Targa / competition car he didnt feel the need ?
But the O2 sensor helps with the fueling...ie with out it you will run to rich....
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
