Coil pack questions...
Postby pervert » Sat Nov 19, 2005 2:09 pm
I've just noticed on my two KE70's that the coil packs are working differently.
On one, the wire from the distributor to the coil pack is going to the negative side of the coil pack, the other is going to the positive.
I know that it should be going to the negative side according to my Haynes book, so stupidly I tried connecting it to the positive on that car, it got rather hot of course... :lol:
Just wondering why the two are different???
pervert
Postby pervert » Mon Nov 21, 2005 7:51 am
Anyone? 8)
pervert
Postby Ae92typeX » Mon Nov 21, 2005 10:10 am
are all the other wires still going to the correct/same terminals on each? -e.g. ignition wire to the positive on the coil?
Ae92typeX
Postby matt dunn » Mon Nov 21, 2005 7:00 pm
When you swap them over,
you have to swap all the ones from the 1st side over to the 2nd side
and all the ones from the second side back to the first side.
Postby Ae92typeX » Mon Nov 21, 2005 7:03 pm
thats a much better way of putting it then my step by step question plan! :D
Ae92typeX
Postby pervert » Mon Nov 21, 2005 7:21 pm
Haha yup, thanks guys, managed to work that one out tonight, I had missed one.
So obviously, the car will run with it set up either way...but the distributor wire SHOULD be going to the negative side of the coil, right?
So if it going to the positive, and the car is running, what kind of problems could this cause? :?:
8)
pervert
Postby Lloyd » Mon Nov 21, 2005 8:09 pm
Basically the coil doesn't care what side you wire things to as long as its all relative. The coil is (as you'd expect) a big coil of wire. You supply it with 12V at one side and the distributor pulses the other side to earth (coil act as a resistor so you're not just shorting a live wire to ground).
If you feed live power to the earth side of the coil and pulse the positive side to earth you're basically doing the same thing.
Postby vvega » Mon Nov 21, 2005 8:37 pm
yeah dosent matter what side
just energises the coil from a different end :d
v
vvega
Postby pervert » Mon Nov 21, 2005 8:40 pm
Thanks heaps guys!!!
pervert
Postby matt dunn » Mon Nov 21, 2005 11:29 pm
vvega wrote:yeah dosent matter what side
v
In more modern elec ign coils it does matter as you get a better spark wired correctly,
as it's where the secondary taps off the primary that matters.
Only ever seen one car in at work where it was the problem that it came in for and it was a mid 90's honda ( is that a swear word in here?)
Postby vvega » Tue Nov 22, 2005 6:29 am
yeap very true in a transisterised coil system
v
vvega
