Better fuel usage......
Postby Demon_Toy » Mon Dec 05, 2005 12:24 pm
Something on the Discovery channel just had a test to see if you use more fuel with your windows down or the A/C on. They did laps of a race track oval in SUV's. The winner by 30mins was windows down.
12.5@110mph MR2 Turbo - In parts to be fixed. AGAIN! Engine rebuild #3
Demon_Toy
Postby Emperor » Mon Dec 05, 2005 12:27 pm
Yep, air con eats your fuel. Round town I have windows down, but open road/long trips I use air con, too noisy with windows down.
Emperor
Postby DJ » Mon Dec 05, 2005 12:28 pm
Like, wow.
DJ
Postby vhpacer » Mon Dec 05, 2005 1:09 pm
Yeh that was on myth busters. But one thing is that they were only doing 40mph. Im sure the result would have different if they were doing 60mph/100kmh
vhpacer
Postby Adamal » Mon Dec 05, 2005 1:15 pm
They should have also had one with the windows up I reckon, just with the temp slider set on cold with the A/C off.
Postby RomanV » Mon Dec 05, 2005 1:15 pm
Since SUVs are to aerodynamics what irishmen are to sobriety, I think the windows down/up wouldnt make much of a difference to their already crappy coefficient of drag.
However if you were in a sports car with a low C.O.D., having the aircon on could possibly be more efficient than having the windows down at highish cruising speeds.
Then again, if you were so concerned about fuel economy, you wouldnt drive a gas guzzling SUV anyway, would you?
Postby luvnit » Mon Dec 05, 2005 1:33 pm
RomanV wrote:Since SUVs are to aerodynamics what irishmen are to sobriety, I think the windows down/up wouldnt make much of a difference to their already crappy coefficient of drag.
or a high performance car
i want a turbo, why not 2... new car
1993 mitsubishi galant vr4 TT
now with a poked rear diff
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1464 - updated with new car
luvnit
Postby GTCRSHR » Mon Dec 05, 2005 2:11 pm
it doesnt exactly take a brain surgeon to figure that out tho does it ...
Nothing to see here ...
GTCRSHR
Postby Leon » Mon Dec 05, 2005 2:14 pm
Um, every driver who has done any of the fuel economy competitions could have told them that. I recall reading that in an Australian "Wheels" magazine 20 years ago.
Postby CozmoNz » Mon Dec 05, 2005 9:51 pm
*ponders if a prius hybrid engine/s setup will fit in an aw11...*
Rayne For President!
CozmoNz
Postby RomanV » Mon Dec 05, 2005 10:24 pm
Tell that to a lotus elise owner.
Or an Arial Atom owner. :P
Also alledgedly some modern v8 powered corvettes can acheive cruising MPGs superior to many 4 cyl engines, thanks to a 6 speed gearbox, and cruising speeds of >1000rpm. :)
Postby Santa'sBoostinSleigh » Tue Dec 06, 2005 8:51 am
i heard/saw something a few weeks ago about some new v8 *cough boat anchor cough* that 'switches off' 4 cylinders when they arent needed - quite a good theory IMO, but how it actually performs in real life would be interesting
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby MrBeef » Tue Dec 06, 2005 8:57 am
yes that is the new chrysler
Any last words?
Box, toaster, Aluminum, Maple syrup...no I take that back..im'a hold onto that one.
My beast!
MrBeef
Postby barryogen » Tue Dec 06, 2005 9:22 am
probably gonna have a new one ripped for this comment... but here goes.
The Honda Civic Hybrid is heaps better(fuel economy and drivability wise) than the Prius... and looks better.
barryogen
2ZZ Guru in training
Postby barryogen » Tue Dec 06, 2005 9:24 am
MrBeef wrote:yes that is the new chrysler
quite a few of the newer V8s do it, and some of the higher end engines have done it for a few years, however, there doesn't seem to be a hell of a lot of benefit to it as you still have to drag all that weight around with you, as well as the technical gear to disable to "spare" cylinders, I won't be surprised to see them get rid of it in the next few years in favour of something else.
barryogen
Postby RomanV » Tue Dec 06, 2005 9:30 am
Fuel economy is just as much to do with the cars weight as anything....
eg. a big heavy car with a small engine, you're going to have to work it hard just to get anywhere.
Or a v8 in a tiny car, will only take a tiny blat on the throttle to get it up to speed. 8)
Postby barryogen » Tue Dec 06, 2005 9:42 am
RomanV wrote:Fuel economy is just as much to do with the cars weight as anything....
Anyone old enough to have owned a 1980 Cortina?
I did...
The 1.6L model used more gas than the 2.0 litre model due to this fact. It(the 1.6) had bigger injectors, bigger fuel pump, there were heaps of hybrid models made(by enthusiests) with a combo of the engines to get the best from them, mine hit 134Mph at it's peak, a speed that in that was bloody frightening.
barryogen
Postby Leon » Tue Dec 06, 2005 11:57 am
Real world fuel economy counts for a lot. For example, you'll find some Corvettes and suchlike that can pull down good fuel economy. With the disclaimer that they can only do that while lapping an empty flat section of road while sitting at 42mph in sixth gear. Then you get a geriatric old little engined car like my nasty old Mira that'd pull 20km per litre when driving to Wanganui and back with three people and a ton of gear in it.
Horses for courses
Postby sigma » Tue Dec 06, 2005 7:45 pm
v8s that turn half the engine off at low revs and back on when u put yor foot down to say pass someone.... as barryogen said, still gotta lug round those extra 4 cylinders of dead weight, IMO why not just get a turbo? same principal
1985 MR2 AW11 20v
sigma
