front only brake upgrade?
Postby barryogen » Tue Dec 06, 2005 3:26 pm
Just pondering...
/me looks at the front calipers, then the rear...
Seeing as the back brakes do little work, why don't people just upgrade the front rotors(and calipers) and put the ex-front ones on the back...
barryogen
2ZZ Guru in training
Postby AceSniper » Tue Dec 06, 2005 3:34 pm
how would the front ones work with the handbrake :roll:
AceSniper
Postby barryogen » Tue Dec 06, 2005 3:38 pm
AceSniper wrote:how would the front ones work with the handbrake :roll:
damn it, I knew I was missing something simple.
barryogen
Postby beeker » Tue Dec 06, 2005 5:22 pm
Some high performance brake kits have a seperate hand brake caliper dont they ?
Not that this really help !
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Ae92typeX » Tue Dec 06, 2005 5:48 pm
There are plenty of cars on the road with a seperate drum internal for the hand brake on rear disk units, in which case you probably could adapt the fronts to the rears...but depending on the application, as you say, rears do very little, so just upgrade the front and scratch touching the back except perhaps a better set of pads.
Ae92typeX
Postby 85AW20v » Tue Dec 06, 2005 5:59 pm
You do have to be careful though that you don't upset the swept area ratio from front to back too much - but I have no idea how much too much is:!:
See ya
Simon
85 MR2 20v
85AW20v
Postby suckymotor » Tue Dec 06, 2005 7:32 pm
hydrolic hand brake but you do need to get it certed
suckymotor
TS Original Member
Postby imdying » Fri Dec 09, 2005 10:30 am
I would be suprised if a hydraulic handbrake was legal in nz, or whether it could be certified. The whole idea of a handbrake, is to have a braking system with only mechanical links. The drum in disc handbrake systems are far superior to handbrake calipers.
imdying
Postby GT4 20 » Fri Dec 09, 2005 11:09 am
Hydraulic handbrake can be legally certed - but only on a race car IIRC. Doing exactly this on my Rover. 355mm rotors with Wilwood 6 pots up front and 300mm with twin pots on the back will require a hydraulic set up. Just right for those handbrake turns :twisted:
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
