Gas flowed 3SGE head on a 3SGTE block
Postby GT4 20 » Thu Dec 08, 2005 9:43 pm
Was lucky enough to get my hands on a cylinder head which had been gas flowed by NZ's top Toyota Guru, Lynn Rogers courtesy of AnthonyM. It had been previously used in an MR2 which had a dyno proven 450bhp. Head was 10,000kms old and came complete with HKS 264 cams.
It is actually from a 3S-GE motor which Toyota originally fitted in their factory to an Altezza. When I got my mitts on it, I sent it to a local head specialist who cleaned it up and pressure tested it. New valve seals were installed, valves re-seated and uprated valve springs fitted due to the rev limit being increased to 8,000rpm.
There are a few minor differences between the n/a and turbo heads which meant a couple of bits of creative engineering were required.
The GT4 uses an EGR (Exhaust Gas Recycle) system as part of its emission control which requires a slightly different valve cover. As a result, a small piece of ally needed to be welded between #4 spark plug hole and the end (as can be seen in the photo below). Otherwise there would be a gap for the oil to splash out. This is due to the EGR 'feed' being at this end on the turbo head.
Also, the 3SGE uses top feed injectors as opposed to the larger side feed on the 3SGTE. So the injector holes needed to be re-drilled to accept the larger injector nozzles.
A fair bit of work has been done on the inlet and exhaust ports to improve flow as can be seen in the next two pics...
As well as increasing power, should also reduce lag quite a bit too :twisted:
Also, decided to 'tart' up the alternator too being as it is in such a prominent position. So it was stripped right down to its single components...
While it was apart, new bearings were also fitted.
And the finished article..
Amazing what a bit of chrome can do if it's applied in the right way 8)
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby RomanV » Thu Dec 08, 2005 9:46 pm
Isnt that a gen 3 NA head?
As opposed to an Altezza head?
Postby GT4 20 » Thu Dec 08, 2005 9:49 pm
I have no idea. Just going by what I was originally told. :D
Gary
GT4 20
Postby RomanV » Thu Dec 08, 2005 9:53 pm
Either way, you should get some good gains out of it. 8)
Postby Malcolm » Thu Dec 08, 2005 10:04 pm
yum :)
now buy my turbo!
Postby GT4 20 » Thu Dec 08, 2005 10:08 pm
All_Fours wrote:yum :)
now buy my turbo!
If it's a GT30 then I may be interested :wink:
Gary
GT4 20
Postby Malcolm » Thu Dec 08, 2005 10:15 pm
even better, it's a blitz/kkk k3t kit :D
Postby RunningRich » Fri Dec 09, 2005 8:15 am
That appears similar to my head (no surprise, being done by the same guy). I didn't have quite as much port work done though.
But didn't you realise that the cams won't work on your engine?! It is well documented that those cams only work on *blue* GT-Fours... gimme gimme gimme
Richard
http://gtfour.supras.org.nz
RunningRich
Postby GT4 20 » Fri Dec 09, 2005 10:28 am
RunningRich wrote:But didn't you realise that the cams won't work on your engine?! It is well documented that those cams only work on *blue* GT-Fours... gimme gimme gimme
Lokks like I'll have to respray the car then :wink:
Gary
GT4 20
Postby Santa'sBoostinSleigh » Fri Dec 09, 2005 11:04 am
ooh now you have a 'bling' alternator - thats an extra 15.2HP right there ;)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Dell'Orto » Fri Dec 09, 2005 11:22 am
Ah, that head is for an MR2, no way its gonna work on the GT Four.
I tell you what, I'll take it off your hands, I have a spare GT Four one here you can use :D
Postby GT4 20 » Fri Dec 09, 2005 12:34 pm
Tell ya what, get LR to gas flow the Gen III GT4 head you have and fit it with uprated springs and HKS cams and I'll do a swap :wink:
Gary
GT4 20
Postby suberimakuri » Sat Dec 10, 2005 8:27 am
i'm sorry, you'll need to take that head back.
it won't fit my quad manifold on trademe.
honda owners still sucking on lemon due to insane noise
suberimakuri
