Santa's always rightGT4 20 wrote:Or is Santa right![]()
TRDmod wrote:<insert big story>
thank you santa and gt420
GT4 20 wrote:: Give me a tight twisty closed road and we'll see who has the quickest car that way![]()
TRDmod wrote:while we are on the subject, 206kw, what difference would a computer make, i mean theres pinz who has HALTECH or something of the sort.
reasonable price, what difference would it make, i mean i thnk all up it would be bout 2500 or something top of my head - i mean i calculated, cost me 170 or so dolars per kilowatt so far, i dont wanna push that past 200 per kw, thats gettign to much, feedf back thanks:d
TRDmod wrote:can you suggest anyone who would and where i could purchase a power fc, for a good price? preferably someone that takes master card of amex cos thats better, i like the points. - Click on my signature![]()
so, what power difference would one get from power fc and a full computer? - In theory, none. The power FC IS a full computer, it completely replaces the factory ECU and each PFC is tailored to the car and engine you purchase it for. For a road car, it makes for great value for money. You CAN drive it on the base maps it comes with, but I would very strongly reccomend against it unless you drive on 100% avgas.
o believe that the cheaper the price, there must be some sort of comprimise....i mean would i need to change injectors, fuel pump etc? - Since you'd be getting the car tuned, you may as well upgrade while you're at it. Depends on how much power you're looking to make, but a fuel pump upgrade at the least is good for security, if nothing else.
barryogen wrote:, but on mine(the 2zzge) I can get a plug in Apexi PowerFc that gives me 30kw
CozmoNz wrote:if it dosnt get it from the ecu, im pretty sure he wont stop...
then its going to go to far.... so youll only be able to run 2psi dave.... coz yaknow, ya only want 30kw
All_Fours wrote:stock output of a 2ZZ is 195hp right?
30kW on that makes it about 235hp (engine). That's close to a stock gen 3 3sgte....from an ecu?
