AE86/5 WHAT STEERING RACK WILL FIT
Postby SKDTOY » Mon Dec 12, 2005 4:11 pm
Hi
Im looking for a non power steer rack for my ae85 and need to find one that fits .
The obvious is an AE85 non power rack but good luck finding them.
so I heard that an AE70 might fit is this true .Any help would be great.
Cheers.
SKDTOY
Postby suckymotor » Mon Dec 12, 2005 5:30 pm
how much you want to pay for a ae85 one
suckymotor
TS Original Member
Postby crispy'86 » Mon Dec 12, 2005 5:50 pm
AE70 and KE70 should fit into the mounts on the crossmember.
crispy'86
RE: How much I want to pay
Postby SKDTOY » Mon Dec 12, 2005 7:37 pm
Cheap as chips sound good to me :lol:
Totaly up to you dude give me an idea and we may have somthing to work on :D
Going to maesure an AE70 Rack up tomorrow hopfully its what im afta.
But get back to me anyway its all about the cost 8O :lol:
SKDTOY
Postby Ae92typeX » Mon Dec 12, 2005 10:11 pm
I recall reading on a site ages ago about a guy putting an ae86 rack into his aw11, so in theory it would also be fine to do the reverse.
It was only the one site however & I no longer have the link, so you would want to confirm with someone or at least measure up and check pinion position.
Ae92typeX
Postby fangsport » Mon Dec 12, 2005 10:44 pm
crispy'86 wrote:AE70 and KE70 should fit into the mounts on the crossmember.
only if you also have the correct crossmember, as the power steer rack needs a bigger clamp on the R/H/S.
find a rusty KE70 and get the crossmember as well. cut the rack mounts off and zap them onto a AE86 crosmember. alternatively, find a TE71 crossmember and rack, as the engine mounts are very similar.
fangsport
Postby crispy'86 » Tue Dec 13, 2005 12:12 pm
Thta's what i meant, the mounts are different on power steer crossmember so you can choose to get manual ae70 crossmember or modify like Joe said
crispy'86
Postby SKDTOY » Tue Dec 13, 2005 4:50 pm
Ahhh gotcha.
Think ill just use my original power steering then. :lol:
Buying an other crossmember and rack will cost just as much as setting up my power steering anyway.
Plus all the effort woth the change over.Lazy as hell
Cheers for your help guys. :wink:
SKDTOY
