Toyspeed virtual drag race competition. *CLOSED FOR NOW*
Postby barryogen » Mon Nov 07, 2005 4:22 pm
damn it, I keep playing with this app, and all I get is "unable to determin power curve exponent", even when feeding in the correct details...
side note: if you change the wheels to 205inches wide, with 50%, it makes your top speed go through the roof... I was trying to figure out WTF I had screwed up when it was hitting 963mph in third. :)
barryogen
2ZZ Guru in training
Postby Silent Knight » Mon Nov 07, 2005 5:14 pm
These figures below are my guestimate figures with the SAFC and Profec Tuned up and I haven't got it on the Dyno yet so I will post stock figures if there's a problem with the below guestimates...
Also the last couple of figures I do not know....will this info do or do I need to get hold of the exact figures?
Car title/user name: JZZ30, Silent Knight
(Engine info)
Displacement: 2491cc
Engine Location: Front
Type: Twin Turbo
(at flywheel)Horsepower@RPM 350hp@6200rpm
(at flywheel)Ft-lbs of torque@RPM 375ft-lbs @ 4800rpm
Compression ratio: 8:5
Redline RPM: 7500rpm
(drivetrain info)
Gears: 4 Speed
Manual/Auto: Auto
Gear ratios (below)
1: 2.804
2: 1.531
3: 1
4: 0.705
5: (if applicable)
6: (if applicable)
Final drive ratio: ?
Driving wheels: Rear
(Chassis and body info)
Car weight in kgs: 1560 (Dry Weight)
front/rear weight distribution: ?
Wheelbase in cms: ?
Tire size: 265/35/R18
Coefficient of drag: ?
Overall height in cms: ?
Overall width in cms: ?
Ground clearance in cms: 20cm (?)
Silent Knight
Postby MikeMan » Mon Nov 07, 2005 5:43 pm
RomanV wrote:Here is an example of what is required.
Car title/user name: MikeMan's 1UZ Starion Project (Estimates)
(Engine info)
Displacement: 4206cc
Type: NA
(at flywheel)Horsepower@RPM ~440HP@7500
(at flywheel)Ft-lbs of torque@RPM ~360lb ft @ 5500rpm
Compression ratio eg. 12:1
Redline RPM: 8200RPM
(drivetrain info)
Gears: 5 Speed
Manual/Auto: manual
Gear ratios (below)
1: 3.285
2: 1.894
3: 1.275
4: 1.00
5: 0.861
6: With that torque why would I need a 6 speed?
Final drive ratio: 3.56
Driving wheels: RWD
Car weight in kgs: 1350kgs.
front/rear weight distribution: eg. 55/45
Wheelbase in cms: 244cm
Tire size: eg. 265/45-17
Coefficient of drag: 0.38
Overall height in cms: 128cm
Overall width in cms: 175cm
Ground clearance in cms: 12cm.
MikeMan
Postby aesc » Tue Nov 08, 2005 9:58 am
I downloaded this programme last night, it is very cool. I had it on my computer ages ago (like when I was 13) and it used to keep me entertained for hours :oops:
My Levin managed a 14.5 1/4 mile which probably isnt far off at all
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Lanius » Tue Nov 08, 2005 12:04 pm
Yep, I'm having heaps of fun playing with it ... the dos version is a bit clunky, but still perfectly useable (and not demo afaik).
Just a couple of things that are getting in the way ... how do I work out co-efficient of drag? And what do I put as final drive ratio if I'm unsure of it?
Lanius
Postby aesc » Tue Nov 08, 2005 12:12 pm
Coeffiecient of drag doesnt really affect the performance much I have found. I used around 0.33-0.35 which seems fairly standard.
Final drive ratio, you could just go into the database of cars the programme has on it and look for something with a 4age and copy it from there?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby RomanV » Tue Nov 08, 2005 3:56 pm
Coefficient of drag drastically affects the cars top speed.
Have a look under the 'drive train losses' or whatever its called, it shows you how much loss aerodynamic drag accounts for at high speed.
Lets just say that it is A LOT.
A few points difference in CD can make quite a difference to top speed, assuming you arent maxed out by gearing.
And on a side note:
I just got all of my engine parts back today, so from now on this will be consuming pretty much ALL of my spare time.
So I wont really have any time to run any more cars through, Ive got a million and one things to do.
Apologies to those who posted their cars without me running it, perhaps you could ask aesc or lanius very nicely to do it for you instead. 8)
Postby Malcolm » Tue Nov 08, 2005 4:39 pm
of course, if you want to play around with your fantasy cars, you could always just download it yourself
I realised this is a wicked program I used to have on an old computer. It's fun to put in ridiculously powerful cars and watch them on a track, they accelerate for a split second then spend the rest of the time decelerating for corners. Fun :)
Postby deaf_rattle » Tue Nov 08, 2005 5:33 pm
i have a program called dyno 2000, which allows you to play around with everything about the motor, and see how it affects the power and torque.
very fun and interesting to play with
Postby Bazda » Tue Nov 08, 2005 6:07 pm
hmm 12.2@197kph
with the cars seats and spare tyre out 11.9@201kph
launching at 2200rpm, hmm I can never launch at 2200rpm it will prob stall, the program seems to give you real shit tyres lol cos my car hardcore wheel spins into 3rd on it.
hmm i must be doign somethign wrong. I put in my old cars stats and it can only do a 13.2 but a higher trap speed than my 12.9 i managed in real life. this program seems like its driving on hard rock tyres...
what am i doing wrong....
Postby SUBARUCONVERT » Tue Nov 08, 2005 9:11 pm
Car title/user name: 1990 Subaru Legacy GT
(Engine info)
Displacement: 1994cc
Type: Turbo
(at flywheel)Horsepower@RPM 260 approx @6000rpm
(at flywheel)Ft-lbs of torque@RPM approx 250+ft-lbs @ 3600rpm
Compression ratio 8.5:1
Redline RPM: 7000 rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.545
2: 2.111
3: 1.448
4: 1.088
5: 0.825
6:
Final drive ratio: 4.11
Driving wheels: 4wd.
Car weight in kgs: 1400kgs.
front/rear weight distribution: 60/40
Wheelbase in cms: 258cm
Tire size: 225/45/17
Coefficient of drag: eg. ?
Overall height in cms: 150cm
Overall width in cms: 169cm
Ground clearance in cms: 16.5
SUBARUCONVERT
Postby Graphite » Sun Nov 13, 2005 6:55 pm
ahh good ole cartest, i've had this program for about 5 years now
its not that accurate. it can't emulate traction that well etc.
it said my WRX should do 13.7, i did 13.57 in real life.
1996 VW Golf VR6 2.8
1987 CRX Si Turbo
Graphite
Postby deaf_rattle » Sun Nov 13, 2005 7:48 pm
that sounds pretty accurate to me
Postby barryogen » Thu Dec 15, 2005 1:03 pm
I've been tinkering with this program for a few hours and wondered what sort of difference it would make to my times if I changed it to say that my car was 1cm wider... interestingly enough it makes my car 1.4 seconds faster and 0.1km/h more on top speed on nurbrugring
adding 5cm to the stock car width gives me 1.6 seconds and 0.4km/h
adding 10cm slows it again to the same as adding 1cm...
I would hazard to guess that it is quicker due to being able to handle sideways forces while cornering better... sould about right?
Here are the times and speeds.
Stock
1.2001 TOYOTA RUNX NA ¦¦ 9 min. 45.6 sec., 140.3 kmh
1cm
1. 2001 TOYOTA RUNX NA ¦¦ 9 min. 45.2 sec., 140.4 kmh
5cm
1. 2001 TOYOTA RUNX NA ¦¦ 9 min. 44.0 sec., 140.7 kmh
10
and yep, I really am a geek.
barryogen
Postby RomanV » Thu Dec 15, 2005 1:19 pm
But that's assuming that your coefficient of drag stays the same, while being a wider car.... Which I doubt would be the case.
Also widening your car (even if its a wide body kit) would probably add a TINY amount of weight, enough to negate the tiny advantage that you gain. :)
Also bear in mind that this program makes HUGE and inaccurate guesses about a lot of things about your vehicle....
it cant take into account things like suspension type, suspension setup etc. It is interesting to get a very rough indication of performance, but thats about it.
It's probably as much of an accurate gauge as Gran Turismo. :)
Postby barryogen » Thu Dec 15, 2005 1:37 pm
RomanV wrote:It's probably as much of an accurate gauge as Gran Turismo. :)
you mean that gran turismo is in-accurate in some way? [/sarcasm]
barryogen
