Finally got the exhaust on the caldina (HERGTT)
Postby H1S_SUB » Wed Dec 14, 2005 6:23 pm
oh well you wont be able to get this muffler seperate, as you can only buy it as a kit, and even then its a mission, unless you know someone in japan who can zip upto super auto bach's in osaka, cause they dont take credit cards or internet transfers, oh and then theres the language barrier :roll:
H1S_SUB
Postby YTWGN » Thu Dec 15, 2005 8:42 am
Your system does hang quite low. I have a 2.5" off the shelf RS*R system that seems alot more snug.
YTWGN
Postby H1S_SUB » Thu Dec 15, 2005 6:22 pm
your wag looks alot higher off the ground than mine whats the distance off the ground to the cross member uder the rear diff?
H1S_SUB
Postby 2LTR Rona » Thu Dec 15, 2005 6:33 pm
H1S_SUB wrote:your wag looks alot higher off the ground than mine whats the distance off the ground to the cross member uder the rear diff?
going by the pics on the first page H1S_SUB your pipe runs under the rear cross member where as YTWGN's runs to the right of the cross member (looking from the rear) as you run the 3 inch as was there not enough room to fit in that space ? or was it a choice (to run under the cross member) based on performance i.e flow ?
2002 Altezza, 1974 KE25
2LTR Rona
Postby YTWGN » Thu Dec 15, 2005 6:58 pm
138mm
YTWGN
Postby H1S_SUB » Thu Dec 15, 2005 8:56 pm
138mm
ok i had a measure of mine and it's 110mm also the pics that i took are deciving, it just looks like i goes under the cross member but it doesnt its just the sweeping bend thats comes off the muffler i guess thats its like that for maxium flow
H1S_SUB
Postby 2LTR Rona » Thu Dec 15, 2005 9:04 pm
ahhhh that it is :wink: when looking at the pic YTWGN took, its actually been taken further forward than from where you took yours, hence why it looked so much different :wink: i would say the longer sweep rather than a sharp one is for the performance flow...either way its still a dam tidy job 8)
2LTR Rona
Postby michion » Fri Dec 16, 2005 12:34 am
H1S_SUB, do you have any pics of how a 3" system passes over the front cross member?
michion
Postby H1S_SUB » Fri Dec 16, 2005 7:34 am
na the system only goes to the front cross member was looking at getting that done @ a latter date when we find out whats happening with the new exhaust emissions laws in 2006
H1S_SUB
