Chip sticks
Chip sticks
Postby 86_rolla » Fri Dec 16, 2005 1:59 pm
is there anyway i can get a chipstick for Blueprint blue paint? Was getting into my car at the mall and the wind blue the door open into another car :evil: and ive got a few stone chips. I think a painter will charge me a few hundi to take all the chips out.
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby FrEsH » Fri Dec 16, 2005 2:42 pm
go to toyota and ask...
FrEsH
Postby Ae92typeX » Fri Dec 16, 2005 2:48 pm
a car paint place, eg car colours in albany will also be able to mix you up a little tin of paint to apply by brush. It take a bit of effort/practice to get it right, but good results are possible.
Also many mobile touch up companies that dealers use. Just afew chips and a door chip would be a little cheaper than afew hundie, but id go with my first option for $$ save.
Ae92typeX
Postby 86_rolla » Fri Dec 16, 2005 2:48 pm
its not a toyota colour, its ford colour hmmmmm mite go e-mail them
Ex cars: 2E corolla
86_rolla
Postby BzzzzR » Fri Dec 16, 2005 2:59 pm
Try Goin to repco Etc ...the last time i was there they had a huge selection of chip sticks that are in the exact factory colours ...just look up the year and model and your away laughing !!! :wink: 8)
BzzzzzzzzR
BzzzzR
Postby 86_rolla » Fri Dec 16, 2005 3:23 pm
Ae92typeX wrote:a car paint place, eg car colours in albany will also be able to mix you up a little tin of paint to apply by brush. It take a bit of effort/practice to get it right, but good results are possible.
Yeh i was thinking of doing that just for the chips like uno on the inside onf the doors and stuff,
Ex cars: 2E corolla
86_rolla
Postby Mr Revhead » Fri Dec 16, 2005 5:04 pm
i can get cans made up for $35 and they match it your sample.... so id be very suprised if you cant get the same where you are
Postby 86_rolla » Fri Dec 16, 2005 5:09 pm
cans? so if its on the gaurd, just mask up a small area then spray. Do i have to do any prep or clear coat?
Ex cars: 2E corolla
86_rolla
Postby Mr Revhead » Fri Dec 16, 2005 5:20 pm
either spray cans or tins
any paint shop can do it
Postby Ae92typeX » Fri Dec 16, 2005 5:40 pm
yep, where I listed does colour match cans for 35 or 40, I think a little less for the pot of paint.
Just imo, but if its just stone chips I'd go for a pot of paint, or spray the can into the lid and still apply with brush. slowly build up the layers untill even or just above (if colour sanding)
when dry if brave enough you can carefully colour sand, and assuming the match is good enough you wont be able to tell without a close look.
if its chipped down to the metal its best to put a little prime carefull on the bottom layer, much as you would when doing the whole pannel.
The reason I dont reccomend simply spraying on stuff like chips is you are covering a much larger area which does not need to be done. It means more prepping, and essentially more practice to get it correct if you dont do it often.
Ae92typeX
Users browsing this forum: No registered users and 43 guests
