Gearboxes: E51 <-> E58 interchangability
Postby ATAl » Sun Dec 04, 2005 6:55 pm
In my ae92 gtz the gearbox (open diff e51) is shot, can a ae101 e58 (also open diff) just connect straight up? Will i have problems with driveshafts or anything else?
I have searched and cannot find anything properly answering this.
Another question: Is there any difference between the lsd and non lsd gearboxes apart from driveshafts and the diff? ie could I get a non lsd box and put an lsd in it and it would then be exactly the same?
ATAl
Postby ATAl » Tue Dec 06, 2005 8:10 pm
Someone must have done this before....
ATAl
Postby IH8TEC » Tue Dec 06, 2005 10:07 pm
you meaning e58 as in ae101 gtz gearbox?
Postby ATAl » Tue Dec 06, 2005 11:04 pm
yep
ATAl
Postby IH8TEC » Wed Dec 07, 2005 4:22 pm
you have a non lsd, ae101 gtz gearbox??????????? everyone else thinks they are lsd,
Postby strx7 » Thu Dec 08, 2005 9:42 pm
some are LSD but not all of them. going by the number of LSD to non LSD ones at the dismantlers i'd say probably 1 in 4 was LSD
Postby vvega » Thu Dec 08, 2005 10:19 pm
well i must have been lucky then cause all iof teh umpteem dosen of the 101 boxes ive ever had has been lsd....
its the pre 101 box's that are a c**t
vvega
Postby vvega » Thu Dec 08, 2005 10:21 pm
strx7 wrote:some are LSD but not all of them. going by the number of LSD to non LSD ones at the dismantlers i'd say probably 1 in 4 was LSD
most dismantlers cant tell if they are or not
oh and if you dont use the 101 axels in them they will apear to be a open diff
v
vvega
Postby ATAl » Sat Dec 17, 2005 9:41 pm
As far as i can tell i have an ae92 gtz non lsd gearbox, it's stuffed, so i'm looking for a new box on trademe. I need to know if i will matter if i end up with a ae101 gearbox or are they all the same anyway.
The lsd question is because i intend on buying an aftermarket lsd for a non lsd box (why buy an lsd box for far more if replacing the diff anyway?) and therefore making it into an lsd box with the use of lsd driveshafts.
Has anyone tried this? Any problems?
ATAl
Postby vvega » Sat Dec 17, 2005 9:52 pm
a ae 92 box will not need lsd shafts..
its only teh viscous 101 box that has that issue
i recoment getting a torsen diff if your getting new as they are far better suited to a fwd aplicaton than a plate type
well dependant on your aplication
v
vvega
Postby ATAl » Sat Dec 17, 2005 10:32 pm
yep going to get a torsen (quaife) diff once i get a replacement box, then rebuild the box with the new diff.
Then the hard part - figure out what driveshafts it needs - i can see this being a nightmare...
But i still need an answer to the original question - can i interchange ae92 gtz and ae101 gtz boxes, ignoring the driveshaft issue?
ATAl
Postby vvega » Sat Dec 17, 2005 11:40 pm
they will both bolt up the same
the internals are very different
if you use the 101 then it will have a viscous
and you will not get around teh axel problem aside from attually having them
the viscous would be fine for you rpurposes
so
just got buy a 101 axel and gearbox setup and be doen with it...
v
vvega
Postby ATAl » Sun Dec 18, 2005 12:22 am
So what you're saying is that if I got a ae101 lsd box it would fit to the engine and the gearbox mounts, but, even if I had the proper ae92 lsd driveshafts they would not fit the 101 gearbox?
ATAl
Postby vvega » Sun Dec 18, 2005 8:57 am
yes 92 axels will not work in a 101
vvega
Postby ATAl » Sun Dec 18, 2005 1:58 pm
Great, that clears that up. Now for the next part: Is the incompatibility in driveshafts because of a difference in the diff only, or is the casing of the box different somehow?
ATAl
Postby vvega » Sun Dec 18, 2005 2:45 pm
the 101 has a viscous lsd the viscous has 2 spiles on one side that lock on a comon axel
with the standerd shaft its not long enough on the spline to lock the couplings togeathier
if i remeber right ly the axel is a little loger to acomodate the extra length in spline
v
vvega
Postby ATAl » Sun Dec 18, 2005 5:06 pm
cool thanks, but i should clear up my previous question, i meant what is the difference between the ae92 lsd and 101 lsd driveshafts ie what stops the ae92 shafts working with the 101 box (do the 92 and 101 boxes use different lsd diffs?)
ATAl
Postby IH8TEC » Mon Dec 19, 2005 3:24 pm
if they are ae92 lsd shafts, they should work in an ae101 lsd box
Postby vvega » Mon Dec 19, 2005 6:51 pm
IH8TEC wrote:if they are ae92 lsd shafts, they should work in an ae101 lsd box
no they wont
they are different
man why do i waste my time :cry:
vvega
