method wrote:You guys are missing the point.
The belt will not stop the plane from moving fowards.
The plane works by pushing against AIR not the GROUND
The wheels are there to in theory create no friction between the plane and the ground.
The ground can do what ever the heck it wants under the planes wheels, it wont stop the thing from moving foward and flying!
PLEASE Think of this
Think of yourself on a bike on a long travelator, you push your self fowards using the railing(air in the planes case) at 1kph, the travelator beneth your bike moves backwards at 1kph. Your still moving fowards at 1kph relative to the railing (air) and your moving at 2kph relative to the travelator.
All you who will say it wont fly are assuming the tredmill under wheels will pull the plane back, it wont! It will just make them spin faster. The idea of the wheels are to minimise the friction between the plane and the ground.
And olliboy, dynamics is the phsyics of moving objects, i did a paper on that at auckland university.
IF THE PLANE WAS STATIONARY, THE WHEELS WOULD NOT SPIN AT ALL.
RomanV wrote:IF THE PLANE WAS STATIONARY, THE WHEELS WOULD NOT SPIN AT ALL.
Just in case you missed it the other times I have said.
V8MOFO wrote:IF THE PLANE WAS STATIONARY, THE WHEELS WOULD NOT SPIN AT ALL.
yes I know that, but that still dosn't explain how the plane will out-accelerate the travelator. The plane increases speed to 5kmph as does the travelator. The plane does it in 3 seconds, the travelator does it in 3 seconds.
RomanV wrote:That is ALL that happens.
The speed of the travelator doesnt stop the plane from moving... it just makes the wheels spin faster.
method wrote:...erse at a million miles per hour, thats just means the wheels will be spinning $&#$% fast, the plane will still move fowards.
vvega wrote:the plane will have velocity
the travelator will not stop it from moving forward
if what some of you were saying was true roller bearings would not work
v
V8MOFO wrote:These points are all assuming there's no friction right?
method wrote:V8MOFO wrote:These points are all assuming there's no friction right?
Nah even there was friction it would be so small compared to the 1,000kg+ plane and all the power the engine has. ITs precisely the lack of friction between the plane and the travelator that stops the travelator from causing the plane to move backwards.
That is the beauty of ball bearings and the wheel
Kudos to who ever invented them
Mr Revhead wrote:ha! i just read all that
and for the record i voted yes before reading it.
