503e
503e
Postby scope » Mon Dec 19, 2005 1:56 pm
hello
does anyone have any information on this engine? pictures or whatever? the most i found was on here http://www.toysport.com/Technical%20Inf ... rticle.htm (about half way down) and someone claiming it can handle 90PSI :?:
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Malcolm » Mon Dec 19, 2005 3:03 pm
from the link above
Aazi wrote:Heres a couple more photos of same racing team's 503E, these were taken at 2004 so somewhat of an old setup i assume.
http://paranoia.tuug.fi/gallery2/v/fintoys/MR-2/album50/album29/185_8546.jpg.html
http://paranoia.tuug.fi/gallery2/v/fintoys/MR-2/album50/album29/185_8548.jpg.html
http://paranoia.tuug.fi/gallery2/v/fintoys/MR-2/album50/album29/185_8545.jpg.html
specs translated:
-displacement 2,1L
-compression ratio 8,0:1
-power 1150hp @ 10000rpm / 960hp with regular pump gas
-torque +1000Nm @ 6800rpm
-Weight with all equipments 210kg
-Engine management = Hestec ( http://www.sci.fi/~hestec2/english/index.htm )
-2 x 1500cc per cylinder (total injectors 8)
-Individual throttle bodies
-Dry sump oil system
-Head is magnesium
-twincam with 10-12mm lift, 16 valves
-Toyota CT44 turbo modified by til-racing
-Air to water IC
-Engine is used in a dragster which performance is 0-400m 6,91s @ 317,79 km/h, 0-100km/h in less than 0.8s and distance needed to reach 100km/h is about 15meters.
more pictures and information at team's website:
http://www.til-racing.com/
http://www.til-racing.com/inenglish.php
Postby no_8wire » Mon Dec 19, 2005 3:10 pm
so its only a 2.1L?...
whats the 2x1500cc bit?
no_8wire
Postby Ako » Mon Dec 19, 2005 3:15 pm
Injectors.
Ako
Postby Tranquil » Tue Dec 20, 2005 5:12 pm
503e was intended to be Toyota's engine for the still born Group C Formula (Jag's XJ220 was designed primarily for this formula aswell). Upon the announcement of the IMSA series, Toyota and Dan Gurney (motorsport LEGEND) joined forces to create the all dominating Eagle GTP car.
Possibly the most important attribute of 503e, was the installation of oversized water jackets surrounding the exhaust ports.
Tranquil
Postby Malcolm » Tue Dec 20, 2005 5:50 pm
do you have a link to your source? Sounds like an interesting article I'd like to read
Postby Mr Revhead » Tue Dec 20, 2005 6:54 pm
same.....
where did the name "503e" come from? as some are of the opinion that its not called that at all.
if i can find the proper code i may be able to order one :twisted:
Postby fangsport » Tue Dec 20, 2005 11:13 pm
Mr Revhead wrote:same.....
can't quote as fact, but the 503 was the race inspired version of the 18RG, but equipped with the 16v head, with later became the 3STG. the name '503' was possibly just an accession number through some trial and error on the project, much like the 2TG derivative of similar title.
fangsport
Postby scope » Wed Dec 21, 2005 1:43 am
you can order them from that site. as seen here http://www.toysport.com/webpages/WebUpd ... 202002.htm
503E GTCC / IMSA TURBO ENGINE WITH INTAKE MANIFOLD REBUILT $17,500.00
503E COMPLETE REBUILDABLE BLOCK AND HEAD $8,500.00
503E PARTS AVAILABLE CALL
pretty cheap eh
scope
Postby Tranquil » Wed Dec 21, 2005 9:08 am
I dont have a paticular source.. just some reseach i did 2-3 years ago when i had a strong interest in this type of thing.
The water jacket thing i read on the mr2 forums years ago . Myte still be in there archives.
The Dan Gurney/Eage/IMSA is just basic Toyota motorport history... Thats all over the web
Tranquil
Postby barryogen » Wed Dec 21, 2005 9:52 am
note the title of the page...
"Corolla Parts List Main"
503e in a corolla... nice.
barryogen
2ZZ Guru in training
Postby Mr Revhead » Wed Dec 21, 2005 10:21 am
nah stuff going through them! i want my discount :lol:
im always very wary of info off that toysport site.....
Postby no_8wire » Wed Dec 21, 2005 12:05 pm
pretty good price I think...What else could you buy for that price that has 1150 hp...at 10000 RPM! 8O
8)
Though I wouldnt want to put it in the aw11...I would be dead before to long!
no_8wire
Postby barryogen » Wed Dec 21, 2005 12:10 pm
no_8wire wrote:pretty good price I think...What else could you buy for that price that has 1150 hp...at 10000 RPM! 8O
a little googling found one that revs to 18000RPM and was ~1650HP... so there are some who think that this is not enough.
barryogen
