Wheel offset??
Wheel offset??
Postby trueno_20v » Sun Jan 01, 2006 8:48 pm
I am buying new mags and i need to know the offset of my advanti acids so i can get the right offset on the new ones, does anyone know if there is only one offset on acids or a way to work out the offset, i have taken a mag off and i didnt see any numbers etc? cheers
ADMIN EDIT: signature too large
trueno_20v
Postby wde_bdy » Sun Jan 01, 2006 9:32 pm
Pull the wheel off and lay it face up on flat ground.
Measure from ground to the hub mounting face (call this A), then flip over and do the same (call this B, make sure this is still to the same mounting face). Add A and B together and divide in half (call this C). The difference between C and A is your offset, If A is more than C the offset is positive if less its negative. You need to be pretty accurate with your measuring though.
Or just take one to the tyre shop to do for you.
Callum
wde_bdy
Postby trueno_20v » Sun Jan 01, 2006 10:00 pm
38 sound right?
trueno_20v
Postby Si » Sun Jan 01, 2006 10:19 pm
yes 38 is a common offset, is it positive or negative
ie was your answer 38 or -38
Current: , '96 SubaruImpreza
Si
Postby trueno_20v » Sun Jan 01, 2006 10:30 pm
positive :D
trueno_20v
