silvertop vs blacktop intake gaskets
Postby Mr Revhead » Sun Jan 01, 2006 4:21 pm
anyone ever compared the two?
swapping my preface lift TBs for face lift ones and i wanna know how close the blacktop one is to fitting the silvertop.
silly toyota only have one gasket for the silvertops and they are the same shape as the prefacelift manifold.
just wondering if anyones compared before
gaskets
Postby Celica RA45 » Sun Jan 01, 2006 5:39 pm
are we talking about the silvers mounting to the inlet verses the black tops then yes both gaskets are different or you talking about inlet manifolds
Celica RA45
Postby vvega » Sun Jan 01, 2006 6:21 pm
yeah man
compleately different :D
v
vvega
Postby Grrrrrrr! » Sun Jan 01, 2006 11:26 pm
i have both pre and post facelift gaskets down at the workshop, could photograph the post facelift on the head if you want.
It lines up with the head pretty well, tho the cutout for the injector (top of the teardrop) is bigger on the gasket than on the head.
Unfortunately i only have a preface lift manifold so i'm busy taking that out to matchup with the head and gasket.
Grrrrrrr!
Postby Mr Revhead » Sun Jan 01, 2006 11:46 pm
interesting......
got a facelift 20v here, and the gasket on that matches the ports on the faceleft TBs...... but there is only one part number listed on the EPC.
think ill have to check for supercessions at work on wednesday.
in the mean time i can use the facelift gasket.
Postby sergei » Sun Jan 01, 2006 11:52 pm
I had both prefacelift and facelift 20v, they have different gaskets. Also ACL sells a gasket kit which includes facelift gasket in it (I know because I've bought one a while ago).
Postby Mr Revhead » Sun Jan 01, 2006 11:59 pm
yeah im gunna look into it a bit more.... throw some different frame numbers into it
Postby Grrrrrrr! » Mon Jan 02, 2006 12:05 am
the prefacelift intake gasket is a horrible thing.. just like the prefacelift intake manifold. very much an upside down T shape port. stick that in your engine and your flow will be shite.
Grrrrrrr!
Postby Mr Revhead » Mon Jan 02, 2006 12:13 am
hence why im not gunna!
i think the prefacelift ones were designed on a friday afternoon after the saki shots had started
Postby sergei » Mon Jan 02, 2006 8:43 am
I think prefacelift gasket/manifold is very similar in shape to small port 16v 4age... In fact I have a small theory about this.. that originally toyota designed quads for 16v then they decieded to go audi way....
Postby sergei » Mon Jan 02, 2006 8:46 am
btw even how horroble prefacelift manifold looks, changing it did not make much diffrenece in dyno results (in fact that little increase I could account for Mine's ECU)...
Postby Mr Revhead » Mon Jan 02, 2006 11:34 am
yeah i dont expect and huge gains, certainly nothing the butt dyno will pick up, except maybe for some throttle response or less flat spots
but i figure if i do every little thing i can to get half a hp and improve efficency etc overall itll make a difference.
it certainly wont hurt and gives me a reason to pull my car apart :D
Postby AceSniper » Mon Jan 02, 2006 2:57 pm
hey man, if you want one I have a ACL facelift one here... from a headset pm a price an I can send it
Adrian
AceSniper
Postby Mr Revhead » Mon Jan 02, 2006 6:05 pm
cheers for that.
but iv got one that will suit on my spare 20v so ill just use that.
cheers 8)
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
